scotspanner
scotspanner
So where do you start restoring a GL1100 that has been neglected for a very long time. A start had been made when first acquired, and a good inspection made of all the parts. All very tired, but the good news was that it was all there, and I did see and hear it run with no strange noises coming from the engine, and all the electrics seemed to work. Good enough for me.
Over the years, between house moves and relationships the bike had been stripped to component parts to aid storage and relocation. Must all sound very familiar to everybody here. I am now in a position to start again.
Due to this pandemic I will have trouble getting some things done. Powder coating and soda blasting to start with. I know where to get it all done, just can't get there.
I decided to start at the top and bottom. The clocks have been stripped and checked. The chrome was passed it, so new bases ordered from CMSNL and rubbers from Dave Silver (no interests with either). All the fasteners will be replaced with stainless ( its an illness), and the mounting bracket rubbed back and painted.
The clock housings have been opened up, loads of good stuff out there on how to do it. The main bodies were in a bad state. At some time the black had been painted by hand, badly, and the rust was starting to take a hold. The mechanisms have been put into poly bags to keep the dirt out. Much time has been spent rubbing back to bare metal, and rattle can etch primer and gloss black applied. I don't like painting, ever, so I'm on my third attempt to get it right. Looking promising this time.
The bike will be a bagger, but still had the rear indicators fitted. Again the rear light cluster was in a very poor state, but over the years I have picked up parts and I have a dresser rear light bracket. The chrome is in good condition, and all the fasteners have been replaced with stainless, ( its an illness). When I get to the electrics, all the lamps will be replaced with LED's.
That's about it for now. A start has been made on the top yoke, and thoughts turned to modifications of various parts.
Pictures will follow when I work out how to upload them. I know there is a help guide for that.
If you have made it this far, thanks. I will keep this up to date as I go along, and with pictures.
Stay Safe
Stay Safe
From the home of Barrs Irn Bru, our other national drink
- RIP: cookie
Re: scotspanner
Waiting and watching ....
Re: scotspanner
Welcome back! I've been in similar circumstances with my projects. It is a survivable predicament, lol! Feel free to ask those 'what the xxxx is this part' and 'how does this go' questions. Been there, done that, maybe even have pictures, lol!
Re: scotspanner
Enthusiasm, raw material, know-how. This will be fun to watch…
Welcome!
Welcome!
Re: scotspanner
...change the belts!
Re: scotspanner
Start-and-stop-and-start again is how many builds go. The hardest part for me being finding the part that you know you have to continue on. Let me suggest just a fraction of a drop of very thin spray silicone lubricant on the bearing that the clock needles pivot on. The grease dries and thickens with time causing slow and inaccurate response. Greasing the worm gear that drives the odometer is good too. Just don't get any grease or oil on the face as the markings are very lightly adhered. You can test the clocks with a battery powered drill in reverse. I chuck the stem from an old pop-rivet which has flutes that will grab the inner square drive enough to indicate about 30 mph one the speedometer.
Re: scotspanner
Hi Guys
Thanks for the welcome.
I had an 1100 back in the 80's, best bike ever. I did all my own spannering, so I'm aware if the weaknesses with the bike. I already have a set of belts. Thanks pidjones for the info about the speedo. It will be done.
Will talk later, its spanner time
Re: scotspanner
pictures... we love pictures
Re: scotspanner
I was near you back in the 70's. Holy Loch. Did 10 patrols on a submarine out of there.
Re: scotspanner
Sunday night progress report
Been a busy week. The speedo and tacho housings have been cleaned, primed (again) and painted for the last time. Not too bad a finish. Moving parts tested with cordless drill, lubricated. Found that the tacho was a bit sluggish counting down from 1000 RPM. There was grease between the cone sections of the drive. Cleaned this out, and now a lot better. The inner cone rotates, and the outer is stationary, the grease was causing drag between the two parts. Cleaned the inside, and then mated the two halves together. Kept them together with a carpenters clamp while the locking ring was peened over and swaged closed.
Would I do this job again. Only if I had to, just a sod to do. Only did it because the rust was so bad on the housings. Next time I will make a fixture to reshape the locking ring to the correct form, again hold the halves together with a clamp while the ring was peened over, and fab a ring tool to swage the ring closed in a press. Why didn't I do this now. Working out of a single garage, back garden is getting cleared this week for a slab to be laid, and then at some point a big shed built. Enough room then for the lathe to be installed. Patience, it will all happed.
New chrome bottom housings will arrive this week, have the new rubber mounts.
Onto the front forks and front brakes. I have a set of forks that were supposed to go into another bike. They have been sitting around for 30+ years, but have cleaned up well. New seals on their way.
I have loads of pictures, just cant figure out how to post them. Help please
Re: scotspanner
I know the area well, I must take the ferry across to Hunters Quay a couple of times a year. Then off to Inveraray, and back home via Loch Lomond. A great days run out.pidjones wrote:I was near you back in the 70's. Holy Loch. Did 10 patrols on a submarine out of there.
I remember the subs being there, and then just going.
Re: scotspanner
We seldom had more time off than to run into Dunoon or Sandbank. Once we did rent a car and went to Inverness and Edinburgh. And I took a tour with shipyard workers to Sterling castle. What we saw was beautiful.scotspanner wrote:I know the area well, I must take the ferry across to Hunters Quay a couple of times a year. Then off to Inveraray, and back home via Loch Lomond. A great days run out.pidjones wrote:I was near you back in the 70's. Holy Loch. Did 10 patrols on a submarine out of there.
Re: scotspanner
Back in '78 Beth and I rode on the Maid of the Loch
Re: scotspanner
Hi There
The maid is being restored at the present time. I have never been on any of the vessels on the lochs. I think the Sir Walter Scott is still operating on Loch Katrine. I will have to make an effort to visit then, they are very local for me so there is no excuse.
Re: scotspanner
Another view.
Time has moved on, and work started. The clocks are now done, just waiting for stainless fasteners (it an illness). A before and after view. Next forks and brakes After a bit of a clean up Dust seals after 30+ years of neglect. After brushing away all the rust what came out with these I didn't want to trust the lip seals so new ones on order. The chrome was redone 30 years ago, and is in very good condition. The original forks from the bike will be rebuilt and rechromed at some point, and mothballed as spares. You can never have too many spares.
Don't mind the wheely bin. Makes a good stand for taking pictures, and makes a quick spray booth.
The brake calipers will be stripped and inspected. All the paint will be removed and sent for powder coating when possible.
Stainless pistons (its an illness) fitted and new seals.
I know stainless has its problems, I use it extensively at work. Galling, work hardening, which grades. I dare say I will mention it all in passing later, but it can look great, stays bright for a long time and can solve a load of issues in the future.
In the Fun Factory again this afternoon
