Bringing Back an '81
- Brass Member
Re: Bringing Back an '81
I had been looking around for a cheap donor engine without much luck, so I decided to split the case and see if this was going to be something I could repair...It is definitely not going to be worth it.
- IMG_3486.jpeg (312.22 KiB) Viewed 367 times
- IMG_3487.jpeg (384 KiB) Viewed 367 times
- IMG_3488.jpeg (378.84 KiB) Viewed 367 times
'81 GL1100
'85 650sc
'85 650sc
Never a good idea to transport a bike on the side stand or the center stand. But at least you got it home.
- Brass Member
- Rednaxs60
Here's a wiring diagram to install a manual rad fan switch. Use mine in the summer while driving in the city/stop and go. Have an indicator light:
2021 Royal Enfield Himalayan
- NotSoLilCrippseys
Ouch. That's a pretty catastrophic rod failure, it seems. Did you overheat that badly? Oil starvation? Hmm.
Sorry.
Staying positive, I'm sure there'll be an 1100 up for sale at a great price - and somewhere near you. Someone will get tired of looking at that dusty, old, perfectly fine but long-abandoned and oh-so-80s Wing sitting in the corner of the shed or garage. It'll be missing things like the left side cover, probably have some issue with the starter, and the tires will be shot. It's the dead of winter, and the owner will be looking to clear it out before spring. Nobody else will be interested because, well, it's winter. But the motor will come back to life in your hands.
Sorry.
In the Stable and Ridable
Active Project(s)
Sold
Active Project(s)
Sold
That looks more like it filled the cylinder with coolant. Piston goes up, coolant doesn't compress, next weakest part is the rod. Then a few rotations of the crank and it starts disassembly. Not in a pretty/good/easy way.NotSoLilCrippseys wrote: ↑Sun Jan 02, 2022 1:29 pm Ouch. That's a pretty catastrophic rod failure, it seems. Did you overheat that badly? Oil starvation? Hmm.
- RIP: cookie
Head gasket ?
- Rednaxs60
Ouch!
- Brass Member
I’m not sure what actually caused the failure, but I know it’s smoked and that the easiest solution is a new engine. I’ve had my eye on a few bikes, ended up getting a running 1980 interstate for $500 so I feel good about that.
'81 GL1100
'85 650sc
'85 650sc
