Page 2 of 2
Re: Janis lives!
Posted: Fri Jul 30, 2021 7:05 am
by Kingpin06
They've got them on Amazon plenty cheap. I've used them plenty of times on other projects, and they've worked fine. Pressure is good and flow rate is plenty. The only thing is I really like the looks of the stock pump.
Re: Janis lives!
Posted: Fri Jul 30, 2021 7:15 am
by pidjones
There are threads on replacing the stock pump diapragm. A quick summary is here:
https://www.ngwclub.com/forum/viewtopic.php?t=9967 Also, 1000 (1100 fit too) pumps come up on ebay. Still very old, though. What I haven't seen a fix for is the pump's check valves which seem to be phenolic.
Re: Janis lives!
Posted: Fri Jul 30, 2021 9:51 am
by Kingpin06
The pressure is 2.5 to 4 psi. The flow states 70 LPH.
Re: Janis lives!
Posted: Mon Aug 09, 2021 8:19 am
by Kingpin06
Re: Janis lives!
Posted: Mon Sep 20, 2021 10:45 am
by Kingpin06
Dropping the seat off tomorrow. Got a lady at work that does a pretty good job on reupholstering. Was thinking about going a little shorter, but I think I'll just have her do it in stock configuration.
Re: Janis lives!
Posted: Thu Sep 23, 2021 11:30 am
by Kingpin06
Pulled the seat, installed new rear brake pads. I was going to tag her when I got the seat back, because it think I'll wait until spring. The I'll have the forks rebuilt by then. Any suggestions on fluid?
Re: Janis lives!
Posted: Thu Sep 23, 2021 4:31 pm
by pidjones
I just use synthetic auto trans fluid.
Re: Janis lives!
Posted: Fri Sep 24, 2021 7:08 am
by Lucien Harpress
I think I've run ATF on every set of forks I've rebuilt. Never had any complains. Heck, the manual recommends it for the GL1200.
Re: Janis lives!
Posted: Mon Sep 27, 2021 1:14 pm
by Kingpin06
That's what I'll do then. Time to order seals.
Re: Janis lives!
Posted: Mon Sep 27, 2021 5:52 pm
by pidjones
Just make sure the tubes are slick, no dings or rust (rust is actually worse than dings).
