Thing 2
- wingrider
Re: Thing 2
Probably just doesn’t want to leave!
Re: Thing 2
Im fortunate in that I have Thing 1 to pull proven and correct functioning parts from. Swapped in the Coils/wires from thing one and Thing 2 starts and runs well now. No knocking, misfiring, or issues with acceleration. Got a set of GL1500 coils off FleaBay, and will be installing them. Getting close.
(2) 82' GL1100's
99' Triumph Thunderbird Sport 900
2006 Triumph Speed Triple
Cincinnati OH USA
Cincinnati OH USA
Re: Thing 2
Boy, she cleaned up quite nice. You will figure out this knocking thing soon, always check the ignition before suspecting a fuel issue. Certainly the belt being off can do that.
- codyjames707
Re: Thing 2
A beautiful bike to start with! Man it is clean! Keep us posted, the things you are changing out, are good things to replace regardless, but hopefully you'll find the issue soon!
Re: Thing 2
Those naked clean gen 2 wings are beautiful!
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
- RIP: cookie
Re: Thing 2
That CB front fender really makes it !
- wingrider
Re: Thing 2
Congrats on BOTM! Did it go to it’s new home, or do you still have it?
- NotSoLilCrippseys
Re: Thing 2
Congratulations! Great work.
In the Stable and Ridable
Active Project(s)
Sold
Active Project(s)
Sold
Re: Thing 2
Well....look who's back.
Thing 2 has been on the back burner since the spring. Issues with terrible knocking on deceleration made for a confusing and frustrating time. ( plus the wife's honeydoo list pretty much kept me outta the barn)... Didn't know if it was valve timing issues. ignition misfiring or a bad rod. All not likely with just 22k on the clock. I pulled the radiator, and replaced the timing belts and made sure they were correct. Pulled the valve covers and checked clearances and inspected rockers. Polished all the covers before re-assembly. Then discovered out of sync carbs will create quite a clatter. Purchased a carb tune pro and balanced them today. Vroom. Engine idles smoothly down to 400 rpm ( insane) and what I though was a rod knock has disappeared. test drove it tonight and she accelerates like a freight train. Never had that much power on Thing 1. (now very motivated to balance those carbs ASAP as well)
BUT.......I'm still getting a weird rattle on engine braking. During rolling deceleration with the engine being pushed by the bike, I get this odd rattle down below. Pull in the clutch, engine drops to idle...noise gone. engage clutch. its back. But the bike runs like the wind. Turn that throttle and instant power, with a great sound.
Anybody have thoughts on what this could be?
I try to recreate it with the bike running, in gear on the center stand, but there's no real engine braking happening and it doesn't sound like it does when riding it. That's when the rear wheel really pushes the engine.
its also hard to determine whilst riding as I'm....driving.
If anybody's experienced this and know how to address, please chime in....
(2) 82' GL1100's
Cincinnati OH USA
Cincinnati OH USA
Re: Thing 2
edit: removed my jackleg suspicions after reading whiskerfish and Pb9717 more probable cause conversations
Cliff (74yrs )
Re: Thing 2
Drive shaft slop?
Re: Thing 2
Yes…..I was thinking the same thing, as its really prevalent in engine braking. How do I address? All bolts are tight.
Also, there’s no more knocking whatsoever, the carb sync removed that.
(2) 82' GL1100's
Cincinnati OH USA
Cincinnati OH USA
Re: Thing 2
Got to figure it out first. Could be a ujoint going or the drive line gears. Push the rubber boot out of the way and inspect the ujoint. Look for any evidence of metal shavings. Then remove the back tire and the final drive. Clean and inspect the gears on the final where the drive shaft hooks up.
I have not done one in a while but there is a fair amount of slop in a normal setup. With the bike on Center in first gear there is probably 2 or 3 inches of free rotation on the back wheel
Re: Thing 2
During refurb and restomod the rear wheel and final drive were disassembled, and inspected. New Honda lube was put on the drive shaft and final drive gears, new 90w synthetic in the final drive. No evidence of anything questionable during that part of the build. Typical play in 1st gear.
I’ll pull the boot off the shaft and check that. More to come…..
(2) 82' GL1100's
Cincinnati OH USA
Cincinnati OH USA
Re: Thing 2
First off I want to thank all those that have provided guidance during the diagnosis of issues with this sweet bike.
But I've comes across quandary I'm having a challenge diagnosing.
Upon startup this evening, I am still getting the odd knock of an unbalanced engine, or cylinders not firing. Here are the symptoms.
- Cold exhaust from right exhaust pipe.
- engine sound as if some cylinders are not firing
- hot exhaust from left side exhaust pipe
- no change in idle when right hand wires are pulled.
- Right hand carbs show fuel in bowls via back out of drain screw. both had gas weeping when backed out partially
- Separated wires on right side from each other to test individually. Both show spark at end of plug when removed and observed. Both make arcing sound when connector put in proximity of installed plug.
- If I remove the left hand bank spark plug connections she immediately shuts down. So it appears the left side is the only working cylinders.
- compression is 150-180 psi in every cylinder
- engine has just over 22K, and was a single owner bike.
So.... I have spark, I have air, I have fuel in the bowls on the right side....so.....
WHY IS THE RIGHT EXHAUST COLD? WHY IS THERE NO IGNITION AS FAR AS I CAN TELL ON THAT SIDE, BUT I HAVE SPARK/FUEL/AIR? WHAT AM I MISSING?
My gut tells me that the other issue with the rattling on deceleration may become minimized if the bike is running properly.
OK experts.......I'm asking for your help. I'm at a loss.
(2) 82' GL1100's
Cincinnati OH USA
Cincinnati OH USA
- 5 Replies
- 432 Views
Last post by Sidecar Bob
- 9 Replies
- 813 Views
Last post by 77Gowing
- 2 Replies
- 1104 Views
Last post by delling3
- 26 Replies
- 2625 Views
Last post by flyin900
