So you reckon about 860lb which is 390kg which makes the chair about 125 kg. Sounds not unlikely, from the specs I've read the single seaters can be as little as 70kg, but some of the 1 1/2 seaters are up to this sort of level.rogue1000 wrote:That is an interesting idea, and I will look into doing it with my second engine...I just rode to the weighing station, and the rig weighs 960# with all the usual gear that I carry, plus some wine and groceries...maybe 100# less without the lead plate, gal.of oil, tools, water...
I should think mine's about the same.
