- Dirt Road Cowboy
Re: Single Carb Conversion 2 Barrel Progressive, Runs Excellent
I didn't read back through all of westgl's posts here or on the other sites, so I could be wrong, but I think he bought the hoses at NAPA Auto Parts. You can check their online site, or just try a google search and see what you can find.
I used PVC plumbing pipe for my "prototype" manifold, and it was working pretty well until my solenoid went out and fried the starter. I haven't had the time/money/ambition to put it all back together again, but maybe this year. . .
78 GL1000
DirtRoadCowboy.com
DirtRoadCowboy.com
OK! Thanks!
Experience is what you get when you didn't get what you wanted.
Do your work with your whole heart and you will succeed! There is so little competition.
Come to kindly terms with your ass, for IT bears YOU!
1999 Valkyrie built from parts. One owner.
1981 gl1100 naked, Cosicud. Sold!
1981 gl1100 naked. New project.
Where can I buy this setup??
- brianinpa
Buy it outright as is? From someone that has done it before, otherwise you need to build it. There are intakes out there that will cut down drastically on the build aspect as well.
Brian
ADC(AW) - US Navy Retired 1983-2003
If you aren't having fun doing it, find something else to do.
1984 Standard - 18,000 miles - Naked... the way it should be
1987 Interstate - 62,000 miles - Resurrected from the rust bucket
I bought the carb years ago as well as the VW manifold part (no hoses though) but never ended up even mounting any of it.ktm513513 wrote:Where can I buy this setup??
PM me if you're interested in it.
How much??can you send me a picture?why didn't you mount it?
If he doesn’t have the Weber 2 into 1 adapter, I have one I’d part with. I have two actually.
I sent you a message.ktm513513 wrote:How much??can you send me a picture?why didn't you mount it?
Never got around to mounting it.
Never got around to the majority of the project of that bike really.
Sent you some pics and info. I have the carb, filter, and aluminum manifold but you'll still need to source/make runners.
- taunusrainer
Hi WestGL!
I have a Weber 28/36 DCD on my GL1000, very similar to Your carb, but not symmetrical.
It now has a 23 and a 27 choke.
According to my old weber tuning manual, the 27 secondary should be perfect for this engine.
But it says the primary should be 19mm, If I read all the tables and diagrams right.
This would explain my rough idle. I was now able to grab a rare 19mm primary choke and the matching jets, and will test this combination as soon as I am back from hospital.
CU
Ray
CU
Ray
1976 GL1000 test mule
1969 Ford 17m 2.3V6
1990 Mustang 5.0 7up conv.
1969 Ford 17m 2.3V6
- taunusrainer
Have installed the 19mm primary choke together with a 110 primary main jet. Runs a bit lean according to my butt sensor so I will try 115.
1969 Ford 17m 2.3V6
1969 Ford 17m 2.3V6
- Rusty Probie
Where did you get the silicone hose for the manifolds? Thanks!
- RIP: cookie
Post is 4 years old … might not be answered.
Welcome though …
Welcome though …
- 3 Replies
- 1787 Views
Last post by 82aspy
- 4 Replies
- 1578 Views
Last post by redglbx
- 9 Replies
- 2475 Views
Last post by rod willis
