I know, I know, this has probably talked about before. Sorry
- Tin Member
But I'm the new guy.
I have a vw with an opposed 4 motor that runs off a single carb and I've seen it done on this bikes on line. I know it would be easier not to have to sink stock carbs. I'd like to get everyone's take on this topic and reasons if I could.
Thanks again...Clutch
Re: I know, I know, this has probably talked about before. S
Ive seen a few post on this as well but no experience of my own. I found a good deal on a 4-1 plenum (all cast) but Im not sure about running it. alot of people seem to have tuning issues
My GL1100 Bobber build
http://www.ngwclub.com/forum/viewtopic.php?f=16&t=57946
Cm drop seat bobber build
http://www.ngwclub.com/forum/viewtopic.php?f=13&t=59199
My home built tools and misc projects
http://www.ngwclub.com/forum/viewtopic. ... 58#p637558
What do you have on your bike, year and what is the problem?
1975 Goldwing #1 SOLD
Done lots. Have a look in our unique carb section.
Been done, but
i think it has more to do with not understanding the stock carbs. I don't recall any posts showing a vast improvement in performance
Of course there's been a ton of discussions about all kinds of different carb setups, and it really comes down to what you want. Take a look in the subforum 'Unique carburetion' under the 'Underground Customizing' forum for a good taste of what's been done...
Most guys that want an improved VW go with dual Webbers. Same here. The flat fours with a single have their own set of problems, one of which is a fairly long run from carb to cylinder. Go to classicgoldwings if you want info, they're happy to give it, and if you do it, you get you own badge by your name. You don't get 72 virgins, but close.
I just feel its hard beat one carb per cyl., equal length runners, and the ability to adjust individual carbs to match the needs of each cyl. Which can be differfent
There is a reason my race bikes have 4 carbs and not one.
- 82aspy
goog randakk single carb conversion
- Tin Member
I have a 76 wing. I'm also not looking for a race bike. I have a CBR for that. I'm thinking of doing it for ease of maintenance and reliability. I know 4 carbs are better for performance. VW guys will tell you that more carbs are better for performance but single carb is ease of maintenance and reliability. 1 cars instead of 4 for maintenance and you don't have to worry about sinking them.
Ok, again go to the unique carb section http://www.ngwclub.com/forum/viewforum.php?f=47 . No need to go to another site. We have quite a few members here that have done single carb and other things too.
- Tin Member
- Tin Member
GL1000 single carb info
I have been reading a lot in this section of unique carbs. But have not scene anyone with "Thee Hot Set Up". Many opinions but no straight up, this is it. Found one guy who will swear by and set up for this GL 1100, but no one on the GL1000. So my question is, at this point is there any new info. I know I can make an intake manifold no problem. Still trying to find the right carb to buy.
Thanks...Clutch
69 Custom BSA
52 Mustang Pony
89 CBR 600(Track days)
TT125(dirt track)
76 GL1000
Thanks...Clutch
69 Custom BSA
52 Mustang Pony
TT125(dirt track)
76 GL1000
- gregforesi
Re: GL1000 single carb info
People have used Pict's, Solexes, Webers, 4 barrel Hollys, and maybe others. CaptainMidnight made a lot of claims regarding his conversion kits but I never saw any dyno numbers on either his, or any other single conversions.
If I was to do one I'd pick something highly adjustable/tuneable (like a Weber) and that also had good parts availability for jets and air correctors. I'd also want a dyno run to find out what the exhaust gases looked like. If it ran well, then knowing the torque and HP numbers would be points of information, but the exhaust gas story would be something I think would be solid useable info to dial the carb in.
Be aware that a fair percentage of single conversions have had icing problems, and that some ebay single carb manifolds simply could not be made to work.
2006 GL1800 (Brutus Maximus)
