Sulfur yellow 76: Megasquirted with tbi
Re: Sulfur yellow 76: Megasquirted with tbi
I wouldn't even mind if this was a DIY kit kind of scenario. I just know it will make things much simpler for us non-electrical types.
This board (the one you just ordered) is just for the CDI, correct?
- Toehead
Ya. CDI with a tach output for megasquirt.
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
- Sugs
I've just been reading your thread and am really impressed. I would love to do this, but man I am skeeeerrd...
_______________________
'79 Honda GL1000 Goldwing
- Toehead
Thanks! It's all a learning process!
Got the bike out for the first time last weekend. It's running nicely. The cool thing about EFI is they are much less picky about sitting. It fired right up and ran normally, with out any of the coughing and farting that carbs get after a winter layup.
I've gotten 5 of the new boards, but haven't put them together yet. I've been house shopping, and preparing to move is taking all of my time. I'll get back to it sometime in the summer, just in time for some more riding!
1980 CB750C (sold)
1980 CB750C (sold)
Hey Toehead, just curious if you had a chance to make progress with your CDI setup or not?
- Toehead
No! I ended up moving to a new town and the new boards are still in a box in the garage!
The furthest I got was getting the bike to run for about 10 mins using the CDI system on a breadboard.
I'll tackle this soon though.. Promise. Life gets a bit busy with a toddler and one on the way
BTW, still running fine. It's in storage for the winter but I had to to move it yesterday and it fired right up, even after being off the tender for the last 5 months.
1980 CB750C (sold)
1980 CB750C (sold)
- Toehead
Still promise to get back to this eventually.....
1980 CB750C (sold)
1980 CB750C (sold)
- Toehead
Still haven't gotten to the ignition, but the bike is still running well.
1980 CB750C (sold)
1980 CB750C (sold)
- 77Gowing
Sorry for my ignorance. What is Ve?Toehead wrote: ↑Fri Apr 08, 2016 6:55 am OK... This is also where I idle. It seemed like that was pretty weak vacuum, but if you are the same I guess it's fine
For idle control, no I am not. The Metro uses a coolant-temperature actuated fast idle valve (it is a wax capsule mechanical valve). I didn't want to run coolant lines to the throttle body, so I removed this valve and blocked it off. Right now, I just adjusted the throttle stop to have a good idle speed when warm. Of course this means you need to nurse the throttle when cold.
However, I have a PWM air control valve that just arrived. One I get my idle VE really dialed in so that it is stable, I will back the the throttle stop off and use PWM air control to maintain idle. This way cold start should be as simple as hitting the start button: No nursing required!
Thanks.
"Less is More" Anonymous
77Gowing
1977 GL1000 "O'le Blue." (sold )
2014 Yamaha 950 V Star (sold)
77Gowing
- Toehead
Volumetric efficiency!
1980 CB750C (sold)
1980 CB750C (sold)
- Toehead
And I still have barely touched the bike
1980 CB750C (sold)
1980 CB750C (sold)
- Toehead
And another year gone lol
1980 CB750C (sold)
1980 CB750C (sold)
