Critique my manifold heating!
- Tin Member
Hey all, currently working on getting my single carb on my GL1000. Im using the Stovebolt carb, with a manifold intended for the Solex conversion which I tried with an EMPI with miserable results earlier this year. I built a simple grid and JB welded it to the bottom of the intake, it would have taken some specialized brazing equipment to mate the steel and copper so this is how it ended up. Using coolant from the head crossovers do you think this will provide enough heat?
1976 GL1000, constant work in progress
Re: Critique my manifold heating!
first, I have no real first hand time with this,
but me thinks , No that won't be enough to due. Look up past bike of the month, MyBuddyHolly and see how he put the water tubes inside the airbox.
Or it could be fine.............................
- salukispeed
I am pretty sure you can just silver solder the copper to the clean steel. . if that helps your design. .
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
- Tin Member
I considered silver solder but with so many joints in a small area I also worried about the low temp solder on the copper joints melting with the higher heat needed for silver solder. Ill be painting the heat wrap with VHT also so heat retention should be ok. If it doesnt work Ill try something else, from what Ive heard the manifold doesnt have to be hot just warm to the touch to prevent icing.
- Oldboy
Sorry to be the bearer of bad news, but coolant is not going to flow through thoses tubes. The coolant is pumped through the heads
into a common housing that leads to a bypass port & thermostat from there to the rad. Your're going to have coolant coming out of each head and running into each other...no where to go. You may also have just made a large air pocket,,,,Sorry just my 2 cents.
Cheers...
Just Wing-it
Just Wing-it
- Tin Member
I thought of that, it doesnt necessarily need to flow as long as it heats up, becoming an air pocket is a concern that ran through my head though. Its significantly lower than the radiator cap but in an awkward position for coolant to run. may have to tip the bike to get it bled.
Any suggestions for a better setup with this style of intake?
- flyin900
How about a 12V heater set up for heating grips on a bike? I don't have any first hand experience with those type of heaters and how much heat they will provide vs what you actually need. They could be possibly wrapped around the intake manifold and wired into the 12v electrical off the key if you need the heat constantly.
If this is a viable option then reducing the electrical consumption on the bike with 12V LED bulbs in the signals and other areas will probably gain you back the extra load from the grip heaters.
If you want to attach the copper pipe to the bottom of the intake I would just use the "Steel Stik" putty that comes in a "tootsie roll" that you knead to activate. I have used it in various applications and it is good for about 500F, so no issue with heat on there. It will definately bond both the copper and metal together in a solid one piece section.
Napa sells it and I think JB Weld also makes an equivalent too, although I like the Steel Stik better since it sets up solid in 15 minutes.
Current Bikes:
- Tin Member
I have considered grip heaters if this idea doesnt pan out. I have no lights aside from LED head and tails, I run an electric fuel pump already though. There is actually a factory heating element off of Ford cars for this carb, I cant recall the amperage right now but its far too much for our factory stator if I remember right.
Check at classicgoldwings.com. They've tried all of the heat sources and have opinions about which work or not. If you're in a climate with extreme changes you may need this. It seems like everyone has to tweak them to their own likings.
- Tin Member
I will check over there, Ive ridden in everything from below freezing to over 100 degrees here so a lot of temp change.
- Oldboy
To make your design work perfectly, here's my suggestion. Take one of the elbows you grafted the copper pipe into
and close off the ORIGINAL tube completely. Now the coolant flowing out off this head must go through your grafted pipe (in
that elbow), through your plumbing and join up with the coolant flowing out of the other head via the grafted pipe in this elbow
and flow towards the by-pass and thermostat. This will guaranty constant flow and maximum heat to your intake. All you are really doing here is changing the path of the coolant out of one side of the engine to the thermostat. Don't make this restrictive.
Ted.
Ted.
Cheers...
Just Wing-it
Just Wing-it
- Toehead
Use the water pump cover and thermostat housing from a 1200 with EFI. it has another coolant loop that you can use for heating your manifold and is a bolt on (with one small mod needed).
Check out my efi build.
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
- Tin Member
Thanks for the suggestions guys, will check out your build and that thermostat housing when I get back to my computer
<iframe width="728" height="410" src="https://www.youtube.com/embed/6IPb_nj6ofk" frameborder="0" allowfullscreen></iframe>Oldboy wrote:Sorry to be the bearer of bad news, but coolant is not going to flow through thoses tubes. The coolant is pumped through the heads
Missed that totally...........yep, your right
- Lead Member
Hi there, I'm gonna use coolant for my manifold. The guy I bought my wing from had already made an alteration because my bike also runs on Propane . On the foto you can see where the alteration has been made. The return hose is fitted at the front.
I hope this may help you.
cheers
arno
cheers
arno
- DSC01484.JPG (130.99 KiB) Viewed 287 times
- DSC01485.JPG (114.61 KiB) Viewed 287 times
- 24 Replies
- 839 Views
Last post by Whiskerfish
- 15 Replies
- 468 Views
Last post by olchris
- 6 Replies
- 381 Views
Last post by pjlogue
- 25 Replies
- 1681 Views
Last post by 5speed
- 37 Replies
- 561 Views
Last post by overboostin
