Yet another carburation idea...
Oldboy
Post by Oldboy »
Time for something different!!! So I made these manifolds... and installed a pair of 1904 Holleys
Gl1100 manifold
Gl1100 manifold
Holley 1904 carbs
Holley 1904 carbs
holley Goldwing
holley Goldwing
Cheers...
Just Wing-it
Re: Yet another carburation idea...
Interesting. Any performance reports?
5speed
Post by 5speed »
Very cool. Love the transparent float bowls.
False tank fit? Looks good.
RIP: cookie
Will we get to see you at the Paris Meet ?
Gord action1
Oldboy
Post by Oldboy »
Well performance wise, I'm not sure yet. At this point it runs and idles well. There's good response from the mixture screw, which is a good sign.
I've got a 2 into 1 throttle cable system that I have to make mounts for and install. Road test is probably 5 to 6 weeks away, but there's always some tweaking to be done.
I don't expect that you can take 2 1959 Rambler carbs, slap them on an 1100 cc engine and have the thing go like a rocket. I'm mostly looking for reliability and drive-ability. As for the false tank, at this point it will have to be notched a little. If I remove the choke units, it won't....will see. Paris is in the plans as of now. Gord do you have another Wing?
Cheers...
Just Wing-it
RIP: cookie
Yep .... couldn't make the ST1100 fit comfortably .... so I'm back 'home' .... ‘82 GL1100i .... R2B5 ....
See you in Paris (or Cambridge for breakfast).
Gord anim-cheers1
salukispeed
Post by salukispeed »
I really like the look. I too love the float bowl look.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
Oldboy
Post by Oldboy »
GL1100 Holley
GL1100 Holley
GL1100 Holley Bobber
IMG_20180318_160051 (1).jpg (190.4 KiB) Viewed 534 times
Goldwing Carb
Goldwing Carb
Goldwing holley Bulldog
Well the weather was nice enough here today to a take a test ride. All went well, considering the air is quite cool and there is no
manifold warming at all. Only put 4 miles on her, will keep you updated as the weather improves. The last picture has a Bulldog decal...
Yeah or Nah to the decal?
Cheers...
Just Wing-it
Decal looks good,...and is appropriate. Hope it makes Paris,...would love to see it
Post by HOTT »
hubba hubba that looks right on tumb2
I think you'll be surprised how well it works.
Bulldog ? Doesn't need it. It stands on it's own. IMHO
Looks good. Looking forward to another report. Did you end up using a one-into-two cable? Or cable to one side and a second from there?
desertrefugee
Post by desertrefugee »
Really nice motorcycle! I do agree with Hott, though. That build is sharp enough that it didn't need the bulldog.
Oldboy
Post by Oldboy »
Thanks guys, used a 1 into 2 cable, reworked and well lubed. I synced the carbs at idle and then synced them at slight opened throttle. This was done by cable adjustment. I also put a balance pipe between both intakes just to play it safe. Didn't realize during build that my left knee rest slightly on the air filter...
Should make it to Paris.....don't care for the Bulldog too much myself.
More testing is still needed, keep you posted.
Cheers...
Just Wing-it
RIP: cookie
Bulldog might look better in red ? Fit in with the TERRIFIC overall look ....
Gord action1
