Fit, refit, and refit
mikenixon
Early 'Wing Guru
Early 'Wing Guru
Post by mikenixon »
When building a hot rod engine, it is often necessary to custom-shape the piston crowns. In fact this is the primary reason for and advantage of forged pistons--they are made to permit this. This Axtel-sourced made-by-JE 97mm piston was going into a really knarly big bore large valve stroked H-D Evo (that eventually made 120 horses at the rear wheel, normally-aspirated), and increasing the valve flycuts in preparation for fitting resulted in a problem, hence the piston was cut in half to confirm that. See the issue?
Yup. No bueno. A little too close. This particular cam/valve/head/piston combination was not going to work. One scrap piston. Next!
Return to “Mike Nixon's Spot”
