My take on the best way to remove 'em. Short video.
http://youtu.be/0AI5_uaKPio
Mikee Minute #13 manifold removal
- mikenixon
- Early 'Wing Guru
- gadelsperger
Re: Mikee Minute #13 manifold removal
Reinstall them using heat, as well?
- mikenixon
- Early 'Wing Guru
You betcha. I recommend it too all my customers of all different models. The best way.gadelsperger wrote:Reinstall them using heat, as well?
Mike Nixon
www.motorcycleproject.com
https://youtu.be/CDnzwDWhN24
- OhioBill
- My Album: http://www.ngwclub.com/gallery/v/wingmans/OhioBill
How do you remove the carb rack without turning the two right manifolds 180 degrees?
You can put the manifolds on after the carbs have been slid into place.
I forgot to mention, a light dab of grease really helps too.
- mikenixon
- Early 'Wing Guru
Most techs do not rotate the manifolds to remove the carb set from the bike. Removing the aircut valve and if necessary one or two tops on the right side makes rotating the manifolds unncecessary.OhioBill wrote:How do you remove the carb rack without turning the two right manifolds 180 degrees?
If rotating the manifolds to remove carbs, be sure and have the clamps fully loosened and damage to the interior of the manifolds (due to the notch) will be minimized.
- 19 Replies
- 324 Views
Last post by Track T 2411
- 0 Replies
- 118 Views
Last post by jdvorchak
