GL1000 float bowl gaskets
mikenixon
Early 'Wing Guru
Early 'Wing Guru
Post #1 by mikenixon » Sun Apr 20, 2014 11:08 am
This may have been posted before by Randakk or Octane, but here is something to watch out for. GL1000 float bowl gaskets can easily shift over and into contact with a float, causing the dreaded overflow-into-the-plenum scenario. Avoid this by not reusing gaskets (especially if the gasket's locating tang is bent or missing), and of course by using quality gaskets such as Randakk's to begin with. Many aftermarket gaskets compound the problem by not being reinforced and thus their shape changes easily, but also because they are cut a little differently and are thus more prone to touching the float, whose pontoons are really close to the sides if the casting in any case. A word to the wise. :)
Mike Nixon
www.motorcycleproject.com
randakk
Early 'Wing Guru
Early 'Wing Guru
Re: GL1000 float bowl gaskets
Post #2 by randakk » Sat Apr 26, 2014 8:27 am
Thanks. This issue was completely resolved in 2008 for Randakk customers
I continue to be amazed that some vendors still sell inferior, non-reinforced float bowl gaskets that are guaranteed to cause problems!
More in the subject here: http://www.randakksblog.com/gl1000-floa ... ket-issue/
mikenixon
Early 'Wing Guru
Early 'Wing Guru
Post #3 by mikenixon » Sat Apr 26, 2014 9:19 am
Thanks for the followup, Randall! :)
Mike Nixon
dk1252
Lead Member
Lead Member
Post #4 by dk1252 » Fri Sep 19, 2014 1:34 pm
Found this out the hard way. I wish I could go back in time for this post. I will read up here before I touch the tools. Thanks!
mikenixon
Early 'Wing Guru
Early 'Wing Guru
Post #5 by mikenixon » Sun Dec 18, 2016 9:19 pm
My apologies. It appears Photobucket has had another of its many crashes.
Mike Nixon
Return to “Mike Nixon's Spot”
Who is online
Users browsing this forum: Bear151556a and 1 guest
