Testing a Voltage Regulator
A place for mechanical discussions that are not motorcycle related. Boats, Cadillac's, mowers, tractors, Trucks Et all.
Moderators: CYBORG, robin1731, Oldewing, Forum Moderators
cafton10
Zinc Member
Zinc Member
My Album: http://profile.imageshack.us/user/cafton10/
Post by cafton10 »
2005 SkiDoo 600 sdi 2-Tec
I have no head light, no tail light or brake light, no hand warmers, no thumb warmer. All fuses check fuses check good with a continuity tester. New battery shows 12.5 volts when not running and 14.3 volts when running so I assume the stator is working. Internet search suggests a bad voltage regulator. If I unplug the regulator leads to the lights and accessories (3) can I test each while running or will this cause problems somewhere? If I remove the voltage regulator completely is there an ohms test? Or can I attach to a 12v source and check each output plug? Thanks for any help.
1975 Goldwing
1978 Goldwing
1994 Ural Tourist
1986 Kawasaki Voyager
1980 Yamaha Exciter 250
1962 Willys Pickup
1950 Willys Jeepster
"It is easier to speak of bulls, than it is to enter the bullring."
Rednaxs60
Re: Testing a Voltage Regulator
Post by Rednaxs60 »
If the battery is showing 14.3 volts with the engine started, I would surmise that the RR is working well. You also have power through the ignition switch to the electrical system. The fuses may check good, but it is the wiring that may be the issue. I would check the circuits in question for power. If there is power at the fuse block - in/out - for the circuits in question, check further down the line. Just a thought.
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2008 GL1800 (sold)
cafton10
Zinc Member
Zinc Member
Post by cafton10 »
Thanks for that. Headed to the garage now. Problem on snowmobiles is everything is very tight. Have to take off the muffler to get to the voltage regulator. Or remove the headlights to get to one of the fuses.
1975 Goldwing
1978 Goldwing
1994 Ural Tourist
1962 Willys Pickup
Rednaxs60
Post by Rednaxs60 »
Forgot to mention grounds. Killer issue on small machines/equipment. Understand the amount of room.
Ernest
2008 GL1800 (sold)
OCR
Post by OCR »
Did they also mention that there is a relay in the console that is prone to failure?
There are two in there and are identicle so you can swap them around to test.
There is also a known ssue with the MPEM "key" not making good contact that will cause run and light issues.
79 CX500custom
76LTD
77Goldwing
Secretary Caroline Lodge 681
wingrider
Post by wingrider »
I was also going to suggest the relays.....
cafton10
Zinc Member
Zinc Member
Post by cafton10 »
Relay is correct. There are two identical. I switched them and the starter won't activate. Switched them back and started up immediately. I'll pick one up tomorrow and be ready for next season.
And just for fun started prepping bikes today!!
1975 Goldwing
1978 Goldwing
1994 Ural Tourist
1962 Willys Pickup
cafton10
Zinc Member
Zinc Member
Post by cafton10 »
New relay in place. Up and running! Thanks to all for the helpful suggestions. Still curious how to test the relay. In another application there might be just one.
1975 Goldwing
1978 Goldwing
1994 Ural Tourist
1962 Willys Pickup
think of a relay as a magnetic switch... there is the power to the magnet (and out the other side) and then the MAIN power in and out. when things are on both the main in and out should light up a test light. If it doesn't the relay is bad
78 constantly modified/customized since 1978, BOTM June 2015 de-evolving this very moment https://www.ngwclub.com/forum/viewtopic ... 30&t=65511
76 Ltd "cookies bike" not ready for prime time,
79 project, finished,
'86 1200 (Beth's) with motorvation sidecar, July 2017 BOTM
'17 HD Road king and 08 HD Heritage softail (Beth's). I guess you can say we have MBS
cafton10
Zinc Member
Zinc Member
Post by cafton10 »
Thank you for that information. I saved the old one, painted it red, and now I'll play with this new information.
Back to the garage. Oh, darn!
1975 Goldwing
1978 Goldwing
1994 Ural Tourist
1962 Willys Pickup
Return to “Trains, Planes, and Automobiles”
