Page 3 of 3
Re: Carburetor Removal, GL1100
Posted: Sun Jul 31, 2011 9:40 pm
by macka
seafoam or atf, I suppose you could run them together, but have never heard of anyone doing this.
Re:
Posted: Sun Nov 20, 2011 11:46 am
by calif wingnut
78AZWing wrote:Can the 1000 carb pack be removed the same way that Roady details for the 1100?
Mine is only running on the 1/3 carbs at the moment and with the points and coils firing front cylinders then rear cylinders the problem is most likely the passages in the 2/4 carbs are gummed up.
And have been reading all Randakks' articles on the 1000. Great stuff!
Thanks for the answers.
Yes, but remove the air cut off valve with a long 22" phillip screwdriver, as it will impede the removal process.
Posted: Fri Apr 29, 2016 3:47 pm
by Sceadufaex
This is awesome info. This might sound stupid. But should I even attempt to rebuild my carbs on my own. I'm pretty good at doing things with a diagram. Especially with you tube walk through. But I have a stuck float valve, and the carbs have never been removed on my 1980 gl1100. What do you think guys. I'd appreciate any help here.
Posted: Fri Apr 29, 2016 5:40 pm
by Whiskerfish
We all had zero experience at one point. If you have the space, the time, the attention to detail and the ability to focus then yes you can probably do a decent job. My first rack took me about 12 hours straight only taking breaks to get a drink and use the rest room. I was very meticulous and they came out prefect. Now many racks later and I can generally do them in about half that time. If you try to go fast and take shortcuts then you are wasting your time and will do it over.
Posted: Fri Apr 29, 2016 10:09 pm
by robin1731
Also, along with the recommended Randakk rebuild kits order his Video. I believe it is made for the 1000 carbs but still good for a first timer to watch. It will show some good techniques.
Posted: Sun May 01, 2016 7:57 am
by Sceadufaex
Thanks guys. I think I can do this. Man these sites are so helpful!
Posted: Sun May 01, 2016 8:00 am
by Whiskerfish
Don't forget after the rebuild you will need to synchronize them.
Posted: Mon May 02, 2016 7:57 pm
by Sceadufaex
Thanks for all the advice. I wil definitely have them synchronized.
Posted: Mon May 02, 2016 9:00 pm
by Roady
And clean out the fuel system ... tank to pump ... and replace the hoses with 1/4 inch fuel line and new clamps.
Posted: Sun Feb 26, 2017 6:00 pm
by Roady
Pictures restored in first post.
Posted: Sun Feb 26, 2017 11:49 pm
by sunnbobb
Good deal. How have you been Steve?
Posted: Mon Feb 27, 2017 1:25 pm
by Roady
I'm doing pretty good. How you been Richard? I see you're keeping busy.
