My bike is a GL1000 '77 with original mufflers.
Last year the union joint part of the drive shaft did break. I bought a new one and new cir clips from CMS:
http://www.cmsnl.com/honda-gl1000-gold- ... F++22.html
This is how the driveshafts looks:
Next was to get the old one out and replace it with the new one. I had some trouble doing that, because I did follow the description from the shopmanual, which says that you have to remove the rear swing arm. I could not loosen the pivot bolts, and was looking for other ways, and managed to get the drive shaft out without removing the swing arm.
I removed the rear wheel and I removed the mufflers, too, which makes it possible to lower the swing arm so much, that I could pull the drive shaft out in the front end between the engine and the swing arm, an replace it with the new one.
The picture shows the new drive shaft on its way in place:
From this I have learned, in order to prevent an unplanned replacement of the drive shaft, it is highly recommended to follow Randakks inspection guide :
http://www.randakksblog.com/driveshalf- ... nspection/
Regards Kjeld
How to replace the driveshaft
- tlbranth
Re: How to replace the driveshaft
Can we get the pictures restored to this thread?
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1975 GL1000
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1975 GL1000
1970 CB750
- Sagebrush
Please read this thread: Gallery Upgrade Challengestlbranth wrote:Can we get the pictures restored to this thread?
fixed, his post was about 15 minutes before I made the announcement.
So no pics? It's useless without them.Whiskerfish wrote:fixed, his post was about 15 minutes before I made the announcement.
78 GL1000 Original Owner 131k
- 4 Replies
- 520 Views
Last post by 70sbudget
- 1 Replies
- 1184 Views
Last post by Sidecar Bob
- 8 Replies
- 607 Views
Last post by sunnbobb
- 16 Replies
- 1809 Views
Last post by pidjones
- 7 Replies
- 535 Views
Last post by RB
