I'll see what I can do and get back to you. My Wing needs a new fan switch so I'm in the market as well.
Tony
Alternative Fan Thermo Switch
- technojock
- Brass Member
- Rusty Probie
Re: Alternative Fan Thermo Switch
Not to upset anyone, and I realize the switch info is a couple of years old, but Sabercycles carries an oem replacement switch for about $50. However I did have a problem getting the harness to connect to the new switch, so I rigged the connection using 2 three inch pieces of wire, two male, and two female bullet connectors, along with some shrink wrap, electrical tape, and rtv to seal everything off. The rigs been in place for about two months now and everything is working great. The bike runs cooler now, probably because the old switch was pretty worn out. Since I was already there, I also replaced the thermostat with one from a 78 Civic ($8.00) bike runs much better now.
- Zinc Member
Hi, I'm new here and I wanted a direct plugin for my aftermarket switch so I just put the two male post in the plastic case [wedged] and filled it with JB Weld.. Works great, I cut a small piece of 3/4" pvc pipe [the depth of the rubber plugin cover] to fit around the plug so the original rubber is nice and tight around the plug when it's plugged in...Remove the blue plastic on the post of course...I almost forgot, I added some wire to the male post to make it longer. I flattened the solid copper wire to fit down the side so its good and tight..you have to custom fit it...then fill it...you know bend here and there to get the correct width and heights..It's not very hard..
- lcallison
I tried the Saber Cycle replacement switch also. That's why I'm reading this thread again. The SC switch turns it on just fine, but doesn't turn the fan off early enough. Once it's on in the summer, it stays on. I'm going to be switching to the TS306 or a manual switch.
Larry
84 GL1200A
79 GL1000
84 GL1200A
79 GL1000
- 5 Replies
- 4501 Views
Last post by UK_Andy
- 9 Replies
- 637 Views
Last post by Sidecar Bob
- 15 Replies
- 1417 Views
Last post by pidjones
- 8 Replies
- 494 Views
Last post by Don R
