Valve stem oil seal swap, leaving the head in place
Re: Valve stem oil seal swap, leaving the head in place
Yep I did that too (put some grease on the stem) and they still keep falling out. That's when I laid it on it's side and the process went much smoother.
Dave D.
84 1200 GW Std
02 1800 GW
84 1200 GW Std
02 1800 GW
Another point I would like to make on replacing the oil seals. I purchase the tool like the one earlier in the post (the one with the tagel clamp). But after doing 6 of the 8 valve one of the small rods broke off of the collar. But a friend of mine came to the rescue with a tool that has a screw type mech. After using both types of tools I would recommend the screw type tool it is more controllable and is much easier to use. I ended up having the rods welded . But if I need to do this job again I am going to purchase the screw type tool.
- IMG_20170813_133209832.jpg (269.79 KiB) Viewed 980 times
- IMG_20170805_232454462.jpg (308.33 KiB) Viewed 980 times
Dave D.
84 1200 GW Std
02 1800 GW
84 1200 GW Std
02 1800 GW
- Rusty Probie
Just joined the club. I'm in UK. Have a solo Moto Guzzi.
Now I also have an old GL1100 trike.
But it smokes a lot!! So started on stripping down to replace the valve stem seals. Also replacing rad hoses, thermostat and of course timing belts.
Never tried to do this type of work myself before! But got a Haynes and some excellent advise from this forum.
So rads off, timing belt covers are off and it is at T1.
But although the centre pulley has a mark at the top or 12 o clock the arrows on the toothed cogs both point towards the centreline of the bike and both the "UP" markings are upside down at the bottom or 6 o clock position.
Is this right? The bike ran OK before starting. Have the toothed pulleys been installed wrongly by a previous owner? Does it matter?
Any advice welcome
Any advice welcome
the cams turn at a different rate then the crank. Rotate the crank one more time (360 degrees), and the cams should be closer to the top. (up at the top)
- RIP: cookie
Ian .... please check your private messages ....
- Rusty Probie
realy usefull , i want to do it next month , like the way to keep the heads in place
Maybe this is late to the party, but you can fashion a decent spring compressor using a wrench, piece of board, and the existing rocker arm bolts/holes. The image below shows it in use, with cotton string fed into the cyl head to keep the valve in place during the process.
Greater Boston MA, USA
Stable as of 26Dec22: '81 GL1100, '10 Bonnie SE, '86 Yamaha Radian, '83 Suzuki GS650L, '14 Moto Guzzi California, '85 Honda V30 Magna
An Interesting method to compress the double valve springs.
Cliff (74yrs )
- 13 Replies
- 1095 Views
Last post by calif wingnut
- 15 Replies
- 1003 Views
Last post by toomanybikes
- 3 Replies
- 296 Views
Last post by taunusrainer
- 4 Replies
- 357 Views
Last post by John Schmidt
- 7 Replies
- 976 Views
Last post by tlbranth
