Shelter lock 75-77 models
Post #1 by Whiskerfish » Wed Apr 22, 2009 11:01 am
How to open a Top Shelter on a 75-77 witout the keys.
Remove the seat. Remove the small colored trim piece at the back of the shelter
Using a long skinny straight slot or something similar find the gap at the back of the shelter frame. Insert your screwdriver there.
Gently slide the screwdriver over aginst the spring on the right hand side of the lock mechanism. Once you feel the spring then push the tip of the screwdriver down. It should not take much effort. Applying a bit of pressure to the top in the direction of opening may help.
She should pop right open!!
heraldhamster
Post #2 by heraldhamster » Wed Apr 22, 2009 11:43 am
good one.
sorta bulldogged custom 1978 GL1000 - "geekster" - daily rider
full Vetter dress 1979 GL1000 - "Barge" - daily rider (currently down)
1986 1200 Aspencade - "Heart of Gold"
1990 1500 Aspencade - It's ALIVE! but with a green drool...
H2G2=42
lsgyger
Post #3 by lsgyger » Wed Apr 22, 2009 11:50 am
Slick! action1 action1 action1
Larry
75 GL1000 in various states of repair/restoration
In the Beginning - http://rides.webshots.com/album/560588072GnCGNH?start=0
...and Now - http://rides.webshots.com/album/564150904HcRkSK
Post #4 by robin1731 » Wed Apr 22, 2009 2:34 pm
lsgyger wrote:Slick! action1 action1 action1
X2
1975 GL1000 parts bike (parts for sale)
bum
Post #5 by bum » Wed Apr 22, 2009 2:46 pm
Hey whiskerfish(chief),
you seem to have all the answers, ok so how do I keep my wife and daughter from hitting me? hahahaha....you might call it wingman abuse!!!! 8)
bum
8 wings + 1 Triumph +2 Musclecars = 1 pissed off wife !!!
d6500k
Post #6 by d6500k » Wed Apr 22, 2009 7:30 pm
OK!...
but since all my tools are in the bag, in the tray, under the locked hatch, that I just closed after fueling with my keys in the place near the fuel cap.....
Just kidden.. really good trick!
Doug k
"The more they tinker with the plumbing, the easier it is to stop up the pipes."
Montgomery Scott
1976 GL1000 LTD
peteybug
Post #7 by peteybug » Thu Apr 23, 2009 9:22 am
O.M.G its no wonder they use to let him work on air craft lolol action1 action1
Post #8 by sunnbobb » Thu Apr 23, 2009 12:38 pm
He's a noted car thief...
b2948kevin
Zinc Member
Zinc Member
Post #9 by b2948kevin » Wed Jun 24, 2009 2:28 am
Major props for this one, Whiskerfish! My lock just fell apart as the whole barrel came out with my key. I searched the forum, and 5 minutes later I have a workaround. Thanks!
-Kevin
77 GL1000 26,000 Miles
82 Shovelhead Rigid Chopper
78AZWing
Re: Sheter lock 75-77 models
Post #10 by 78AZWing » Mon Oct 17, 2011 10:24 pm
On my '78, if you push the lid at the lock end to the right, the lock will disengage. You have to really mean it, though.
For that run-down feeling -
Try Jaywalking!
1978 'Wing with Weber conversion, UnDressed
1976 Junkyard 'Wing with a Dyna ignition. Otherwise undressed.
Proud member of the "NGW CARTEL"
Hal
Post #11 by Hal » Wed Oct 26, 2011 7:19 am
It worked for me! I thought my keys were inside, but sadly they weren't.
nor all your Piety nor Wit
1977 GL1000 in bits
1978 SR 500 Yam
2002 Caterham SV 220 Evo (4 wheeled motorcycle) :mrgreen:
Hal's Nalbum
taylorsel
Post #12 by taylorsel » Tue Oct 22, 2013 6:18 pm
That's also a good trick if you don't close your gas cap and it jams. I did that once and thought id never get it open.
STEVE LOGAN, 1979 GOLDWING, 1978 GOLDWING, 1976 GOLDWING
77Gowing
Post #13 by 77Gowing » Sun Jun 26, 2016 9:17 am
Great tip WF.
Your pics and written description make it very clear to understand, so I expect even I can do this.
A wise man has many counselors, NGW is one of mine
"Get your facts first, then you can distort them as you please." :drunk Mark Twain shakehands
I believe in the Scientific Method...you screw up and then learn from it. anim-cheers1
Yes you have a right to do most anything you want, but the consequences are all your own. :oops:
It costs nothing to be nice or respectful.
Kenny 77Gowing
1942 T23 Pershing Tank, Gasoline engine/electric drive. (@ Ft. Benning)
1977 GL1000
2014 Yamaha 950 V Star (sold)
2017 Indian Scout Std w/ABS
Post #14 by ericheath » Wed Jul 11, 2018 4:26 pm
Boss, this will be easier to find as a reference if the title is fixed to Shelter not Sheter.
Post #15 by Whiskerfish » Wed Jul 11, 2018 5:08 pm
ericheath wrote:Boss, this will be easier to find as a reference if the title is fixed to Shelter not Sheter.
lolol lolol lolol lolol lolol lolol lolol lolol
Ok i guess action1 action1
Who is online
