Breaking Clutch lifter plates and how not to!
- J4BPX
- My Album: http://www.aeromount.com/gallery
Despite all the warnings I managed to break the clutch lifter plate on installation. Borrox! In my defence I was being very careful but still it broke. After much agonising l have changed my thoughts on why the clutch lifter plate broke - and I think it is a little more that just tightening it down evenly.
So one clutch unit sourced from ebay later - I recorded the next installation + plus my thoughts on how not to break clutch lifter plates!
Hopefully it might help others who are as hamfisted as I............................
Apologies for the pictures - I write my notes in MS onenote and this is the only way I can find to add the files. Now if I could upload a pdf..........!
- 2012-12-27_110854.jpg (43.15 KiB) Viewed 698 times
- 2012-12-27_111043.jpg (46.46 KiB) Viewed 698 times
- 2012-12-27_111104.jpg (43.42 KiB) Viewed 698 times
- 2012-12-27_111123.jpg (46.71 KiB) Viewed 698 times
- 2012-12-27_111155.jpg (55.8 KiB) Viewed 698 times
A little inaccuracy sometimes saves tons of explanation - Saki
1976 UK GL1000 K1 'Trog' restored.
What's next?
The restoration at http://www.aeromount.com
What's next?
- J4BPX
Re: Breaking Clutch lifter plates and how not to!
And More
- 2012-12-27_111215.jpg (38.35 KiB) Viewed 695 times
- 2012-12-27_111231.jpg (49.16 KiB) Viewed 695 times
- 2012-12-27_111246.jpg (60.64 KiB) Viewed 695 times
- 2012-12-27_111300.jpg (50.83 KiB) Viewed 695 times
- 2012-12-27_111313.jpg (60.79 KiB) Viewed 695 times
What's next?
What's next?
- J4BPX
Last
- 2012-12-27_111329.jpg (27 KiB) Viewed 695 times
What's next?
What's next?
- J4BPX
I'm sure I was over complicating matters and some will quibble with the technique - but that is what forums are for........... healthy criticism.
Nb: When measuring the depth of the plate - I didn't measure at just one point - I measured next to each bolt!!! The pictures just shows one for clarity.
What's next?
What's next?
Nice, thanks for sharing and clarifying. I have yet to do this, but I now think I could.
- roachb
I broke two of them and was thinking along the same lines as you. The other line of thinking is that it has to do with the proper alignment of the springs. I was not so convinced of the spring theory. My first two attempts I was installing heavy duty springs. The third time I went back to the original springs and was successful. I also did a little beveling to help the posts slide into the slots. So I am not sure what made it work. I was also very slow and methodical with the tightening to keep the plate even.
RoachB
'75 GL 1000
'79 CM400T
"If you're going to repair a motorcycle, an adequate supply of gumption is the first and most important tool."
- Robert M. Pirsig
'75 GL 1000
'79 CM400T
- Robert M. Pirsig
Roachb,
Thanks for this little bit of info. I just broke one and was thinking that I had been careful with spring alignment and the tightening sequence, but broke it anyway.
This improper figment between the clutch plate and the spring carrier(?) might be my problem too, or I'm merely hamfisted...
I'll try the dry fit first with the new plate and cross my fingers
- roachb
And say a little prayer. Good luck with that. I still can clearly recall that horrible "tink" sound.
RoachB
'75 GL 1000
'79 CM400T
- Robert M. Pirsig
'75 GL 1000
'79 CM400T
- Robert M. Pirsig
- rogue1000
I broke my last one by dropping it on the concrete floor as I was cleaning it. I have also found that the aftermarket springs are a tiny bit larger in circumference than the oem, so you have to really pay attention that they are seated.
- MSGT-R
- Lady Winger
Wow, what a painful lesson!
81 Interstate: gone but never forgotten.
13 F6B
NGW Cartel
13 F6B
NGW Cartel
- dl1000
Great write-up. Will no doubt save many a broken plate.
1978 GL1000.....KATE Daily ride
a very wise man once said nothing
And many thank to J4PBX for starting this post and including detailed pictures and diagrams. Big ups!
- 1983lux
Nice thread, might be a good one to add to shoptalk
1975 Honda GL1000 - Naked
Motor from 1979 Model
1975 Cams and Carbs
Dyna S Ignition
1975 Cams and Carbs
Dyna S Ignition
- 7 Replies
- 718 Views
Last post by robin1731
- 20 Replies
- 938 Views
Last post by Sidecar Bob
- 5 Replies
- 271 Views
Last post by odyssey
