Page 2 of 3
Re: Brake Caliper Piston Removal Made Simple
Posted: Wed Nov 13, 2013 10:14 am
by tomk1960
ericheath wrote:Nice vid. I look forward to the others. Growing up in Cow Hampshire and going to college in Mass, the accent was like music to my eahs.
And here I thought I had a neutral accent...I guess some of the "Wistah" in me came through, eh?
Posted: Wed Nov 13, 2013 10:47 am
by Topwingnut
Great video and excellent quality ... Look forward to many more ...
Posted: Wed Nov 13, 2013 11:13 am
by abert51
very nice contribution to the site Tom (and son in law). Thank you.
Posted: Wed Nov 13, 2013 11:15 am
by abert51
'wistah' as in Worcester MA. I'm in Sutton. golly.
Posted: Wed Nov 13, 2013 12:30 pm
by tomk1960
abert51 wrote:'wistah' as in Worcester MA. I'm in Sutton. golly.
Just 20 minutes down the road from me...we have enough local NGW members (at least 3) to start a Massachusetts chapter!
Posted: Wed Nov 13, 2013 7:11 pm
by Toehead
tomk1960 wrote:abert51 wrote:'wistah' as in Worcester MA. I'm in Sutton. golly.
Id say at least 5
Posted: Wed May 27, 2015 5:17 am
by bonestock3
So I'm very new to this, I've watched this video several times and I get the idea, but I'm trying to figure how to get to the bleeding aspect of things from a stock standpoint. I figure Caliper off, brake pads out, but then what? Does it bleed automatically? Should something specific be removed to allow the flow of brake fluid? What? I need to get into my right caliper but plan on going through the whole braking system for a thorough cleaning and inspection. Where should I start? I've watched all your YouTube videos (I'm a fan) but still not sure where to start. Thanks in advanced.
Posted: Wed May 27, 2015 9:19 am
by Whiskerfish
For the most part you need the system complete and installed. Otherwise the pistons would just be pushed out of the calipers
Try some reading here
http://en.wikipedia.org/wiki/Brake_bleeding
Posted: Sat Oct 15, 2016 10:27 am
by Youngster
This video is great - very helpful. Is there any reason why one couldn't just pull the calipers off the rotors and leave them connected to the master cylinder to complete this function? I could imagine that the mess of brake fluid so close to the bike would be an issue, but otherwise it seems possible. Also, do you have any tricks for getting new Pistons into the calipers after rebuild? Thanks!
Posted: Sat Oct 15, 2016 2:04 pm
by Toehead
If you get all the scale out of the seal grooves (I use a brass wire brush wheel on a dremel), the piston should go in with hand pressure. Lube the seal with some clean brake fluid first.
If you have to force it with a press or clamp, something isn't right.
Posted: Sun Feb 26, 2017 4:19 pm
by 5speed
just getting into rebuilding my brakes and subscribed to your video's Tom.
Posted: Tue Mar 17, 2020 10:00 am
by boogie red
Nice video, cool setup, what about this, I just pull a caliper off leave everything hooked up get my spacer setup start pumping!
See what happens, this will be fun, thanks again
Posted: Tue Mar 17, 2020 9:51 pm
by tomk1960
Smart move! That will do the trick and you saved time by not having to set up on the bench.
Posted: Sat Apr 11, 2020 7:38 pm
by boogie red
Tom, like I mentioned before there's a cool setup, here's what happened to me, I pop that caliper off and commence the pumping the Piston out this using my brake on the bike it came right out of course you got to separate the caliper to get it all the way out so I'll go over to the other side and I'm like oh hahaha, Hydraulics are open now so I got a Bolt & Nut exact size use the washers put them in that banjo fitting start pumping, well no pressure well that means I had to go back over and bleed it out! pump the other piston out Wawa awesome, they weren't that bad of shape I just polished everything all up, cleaned out those grooves where the seal set everything was just corroded and dirty, even use the same seals, they still had elasticity and I just use some Scotch-Brite and it worked really well I was amazed, feels real good resemble bam I got brakes! bike even runs oh, now I get to do the rear, good stuff life is good, be safe out there in that crazy world right now
Posted: Wed Sep 15, 2021 12:37 pm
by oldawg
Good common sense approach... thank you!
