Bad u joint on my GL1000
Re: Bad u joint on my GL1000
Mine was the one from DrivetrainAmerica
for you guys that have replaced them..how are you removing the old one?
Thats where I ordered mine from
I pressed one cup inward forcing the cup on the opposite side to come out as far as possible before the two halves of the yokes came together. I then pressed from the other side using a pitman arm remover to straddle the other side of the yoke and pressed the opposite cup out as far as possible. That allowed me to remove the cross from the center. I then repeated the process with the other yoke.
I can probably get a pic or two to help explain.
1975 GL1000 Restored (sold)
1983 GL1100 Custom (sold)
pics are awesome.MikeNTexas wrote: ↑Tue Dec 29, 2020 11:01 amI pressed one cup inward forcing the cup on the opposite side to come out as far as possible before the two halves of the yokes came together. I then pressed from the other side using a pitman arm remover to straddle the other side of the yoke and pressed the opposite cup out as far as possible. That allowed me to remove the cross from the center. I then repeated the process with the other yoke.
did you do anything about the factory stakes holding the cups in?
No I did nothing to the factory stakes. The old cups pretty much smoothed them out on their way out. I thought about smoothing them out some more before installing the new ones but I figured the extra interference would help hold the new ones in
Here’s a couple of pics of what I used to press the old ones out.
- AC82B562-58DF-48B4-A01E-536102EE80AA.jpeg (272.45 KiB) Viewed 929 times
- 678FCE14-4C9C-441C-AF20-C00169E9E0F1.jpeg (251.82 KiB) Viewed 929 times
the pitman arm tool is genius..
got my U joint from Fed Ex today. Looks good. If it works out I should have about 4 spare 1000 drive shafts
Rebuilt one of my driveshafts this morning. The joint is perfect. I sealed the connections in epoxy, and it looks like it will work very well. I need to order a few more to do the rest of my spare shafts. I have to figure out a way to test them to insure they will work. Might try a driveshaft shop to see how they spin.
that would be very useful info.CYBORG wrote: ↑Thu Dec 31, 2020 1:31 pm Rebuilt one of my driveshafts this morning. The joint is perfect. I sealed the connections in epoxy, and it looks like it will work very well. I need to order a few more to do the rest of my spare shafts. I have to figure out a way to test them to insure they will work. Might try a driveshaft shop to see how they spin.
- Zinc Member
Hi , is there apart number for the u-joint from Drivetrain America ? Cheers .
76 GL1000 ,73 Norton mk5 , 75 Triumph T160 , 49 Matchless G80 500 rigid ,and
X4 76 HondaTL250s
X4 76 HondaTL250s
https://www.drivetrainamerica.com/neapc ... r-u-joint/Bloodhound wrote: ↑Tue Nov 16, 2021 7:32 pm Hi , is there apart number for the u-joint from Drivetrain America ? Cheers .
- 21 Replies
- 1451 Views
Last post by redglbx
- 12 Replies
- 433 Views
Last post by Whiskerfish
- 4 Replies
- 192 Views
Last post by ericheath
- 8 Replies
- 298 Views
Last post by Shadowjack
