Alternative Fan Thermo Switch
- AZCycle73
This is an addition based from Roady's original thread here.
_____
I installed the Geo temperature switch this evening, with a little creative wiring. I didn't want to remove the original plug, in case I wanted to go back to an original style switch in the future. Some of you guys probably already figured this out, but I thought I'd at least post my process in case it helps some of you...
First off, I noticed that the original switch connectors were about the same size as some bullet connectors I had, so I worked backwards from that. You can see the bullet connector on the left, original switch, and the new Geo switch.
The area inside the Geo switch is so cramped that even two small blade connectors didn't fit well. They DID fit but were touching, which is not a good thing. So I took the blade connectors and trimmed back the plastic sheath, but left enough to protect the crimp area.
I then soldered a 3-4" length of wire onto the BLADE part of the connector, and then protected using some shrink tubing.
On the opposite side, I soldered two of the large bullet connectors, and of course... more shrink tubing.
The crimped part of the small blade connectors slid over the Geo switch just perfectly!
So I have this:
Electric taped it really well:
The bullet connectors fit into the original plug really well. They seem nice and tight and don't move around so I assume they're good. Not sure how I'm going to protect them from the elements. And I may have to zip-tie the wire away from the fan blades.
_____
So I have this:
1976 GL1000 - in progress - 70,000 miles - Originally Sulfur Yellow
- AZCycle73
We'll see... I have yet to hear my 'wing even start yet so functionality of the new temp switch is up in the air. But others here are using them, some with good results and others with mediocre results.65olds88 wrote:Does it work as well as the factory one?
Once I get my 'wing up and running, I'll certainly post back with results.
My homemade switch is probably good. I had thought that it wasn't working but after getting everything back together with the OEM switch in place ... the fan still didn't work.
I jumpered the fan and it was not working.
Tore it apart again and got the fan motor out and found rust/corrosion and gunk inside. I polished it all up, reassembled and like magic it works perfectly now. Temp never goes above about 1/2 way on the meter.
So, I guess I've got a spare switch now.
- roncar
Ok, I must have missed it. If you have never had the engine running, how did you determine the original temp switch was bad?AZCycle73 wrote:We'll see... I have yet to hear my 'wing even start yet so functionality of the new temp switch is up in the air....65olds88 wrote:Does it work as well as the factory one?
- AZCycle73
You caught me. I assumed it was bad because the PO had hard wired the fan directly to the battery. In all honesty, I figured that while I was in there, radiator out, timing belts, replacing o-rings, etc., I might as well bite the bullet and put in a new temp switch. Then I saw the "how-to" and got intrigued.roncar wrote:Ok, I must have missed it. If you have never had the engine running, how did you determine the original temp switch was bad?AZCycle73 wrote:We'll see... I have yet to hear my 'wing even start yet so functionality of the new temp switch is up in the air....65olds88 wrote:Does it work as well as the factory one?
I wonder about the threads/size?ElPiloto wrote:There was a Geo Turbo that was sold in Canada. It has the turn on point about 10 degrees lower than the regular Geo switch. That might be the way to go here in Arizona.
Testing Your Switch
You test the switch by suspending it in a pan filled with some motor oil. Heat up the oil and watch your dollar store candy thermometer. Hold the leads of your meter on the connectors. If it switches on at temp then it's good to go. If it doesn't then it's toast (& $59 to www.ServiceHonda.com).
Kinda like this:
Butt, my meter was setup wrong in that pic. Read the rest of this thread to get more details.
A similar test can be done on the Water Temp Sender.
Detailed instrux and temps can be found in the manuals.
It's the same 3 cylinder 1000 cc engine, so I would have to believe it's the same size, but with a different turn-on temperature.I wonder about the threads/size?
Since the Geo is out of production now, and the turbo Geo's are very rare, I imagine it would be difficult to find the switch now. But, the next time I see one listed in a catalog, I am going to try to order one.
Who knows?
I was looking for more info on this switch. It looks like Steve Saunder's Forum really took off on this idea. Check out their thread here.
Here's a cut-n-paste collection of more data on the switch, and other options available. I haven't checked these out, just going by what the gang over at Saunder's is saying about OUR fix.
Valid for 1975 thru 1987 GoldWings.
1994 Geo Metro 1.0L, MR Series
Closed Switch Temp Range=88.5c to 91.5c.
Open Switch Temp Range=82c to 88c.
The Part Number Collection:
I didn't have a problem with the Geo switch and NAPA #101 Thermostat. Roady
Peterbylt did a pretty nice job on his adapter. Since he stole my idea (while only crediting this board), I stole his pics.
All's fair, eh?
- BWD #TFS596 40-5079
- Beck Arnley #201-0817 ($20.00 RockAuto.com)
- Gates #T274 (RockAuto.com $16)
- Borg Warner #TFS596
- Echlin #FS-130 (36.77 NAPA)
- Niehof #WA-639B
- Four Seasons #35934
- Autozone #002683
- Car Quest #TS-306
All's fair, eh?
- technojock
- Brass Member
I doubt you could move that many here but it you put together a package of the connector and the switch and made it as plug and play as possible I think you could do very well on Flea BAy.
While researching EFI sensor connectors, I found that GM makes pigtailed connectors for amost every electrical plug on any recent GM car.
If you could get the connectors for the Geo switches and sell them together, as I'm sure, as Whiskerfish suggested, that you could sell a bunch of them on eBay.
Good luck
Good luck
- 5 Replies
- 4540 Views
Last post by UK_Andy
- 9 Replies
- 644 Views
Last post by Sidecar Bob
- 15 Replies
- 1443 Views
Last post by pidjones
- 8 Replies
- 500 Views
Last post by Don R
