different exhaust temps
- the chef
- Location: Odenville,Alabama. The land of dixie! (!Hell yeah!!)
I had the pipes off the machine yesterday and dicided to crank her up and see how loud it really was , i only ran it a minute or two and when I put my hand down to feel the exhaust I noticed the front cylinder s exhaust was much hotter than the one in back, whats up with this? the chef
On the highway to Hell!
Ride on, Ride on.. !
PREVIOUS OLD LOVES=
19?? Zundapp with 6 hp Briggs and Stratton engine Chrome tank
1971 Kawasaki H1 500 blue /white stripe
1975 Honda 750 Yellow
1980 Honda Gl 1100 Interstate Black
1982 Honda Gl 1100 Standard Black
1983 Honda Gl 1100 Aspencade Black
1981 Honda Interstate Black
1981 Honda Gl 500 Silverwing . Candy muse red
1986 Honda VT 500C red
PRESENT RIDE >1976 Honda Gl 1000 Originally red, now flat black, olive drab, primer gray.
PREVIOUS OLD LOVES=
- RebelRouser
- Webmaster (Retired)
- My Album: http://www.ngwclub.com/gallery/v/wingmans/rebelrouser/
Hey Chef;
Sounds Like You Need To Do One Of 4 Things, Sychronize Your Carbs, Adjust Your Valves, Check Your Sparkplugs Gap And Fireing, Or Check Your Compression....
And Theres Probibly Other Thing I'm Not Thinking Of Right Now....
- the chef
ex.
hmmmmmmmmm....this bike only has 14,000 miles on it, had only 8,500 on it when i bought it , im thinking its not ready for valve adjustment or has any compression problems, but I could check. has new plugs gapped them myself at .022. where are you from reb? are you a southern man? i mean you dont like cornbread!!!??? thanks come back, the chefRebelRouser wrote:Hey Chef;
PREVIOUS OLD LOVES=
PREVIOUS OLD LOVES=
- RebelRouser
Southern In Heart, But Western In Location.... Reno, Nv...
I Would Still Sudjest You Check The Above Listed Items... Any Thing And Everything Can Have A Adverse Efect On The True Performance Of A Machiene.... But Like I Said Before I'm Probibly forgeting Something That Could Be The Culperate....
- quakeholio
Valve clearance shouldn't be put off for too long, and I would say that it's time you check your clearances. The clymer manual for my GS1100 said check them every 600 miles, that is insane or wrong, I don't know wich it is. At any rate I would look at the valves every 5k myself.
My bike was having a problem like that two, but I would say that #1 was cold and the rest were the right temp. Turned out when I did the carb rebuild a piece of brass got into one of the jets. Haven't had a problem like that sence then.
- the chef
this bike sat out in the yard uncovered for a year all i had yo do was charge the battery and she cranked right up, so there may be some varnish buildup in that carb, i hate to rebuild a carb i have 4 of them dissasembled in a box already (got them that way) but i will check into a valve adjustment rightaway first thanks the chefquakeholio wrote:Valve clearance shouldn't be put off for too long, and I would say that it's time you check your clearances. The clymer manual for my GS1100 said check them every 600 miles, that is insane or wrong, I don't know wich it is. At any rate I would look at the valves every 5k myself.
PREVIOUS OLD LOVES=
PREVIOUS OLD LOVES=
- quakeholio
Valves are setscrew adjustment type. Very easy to do.
WF
WF
- quakeholio
- octane
Hi Quake
Here you go:
GL1000 valve adjustment:
Octane
Here you go:
Octane
Da' Supercharged Bulldog
Antoine de Saint-Exupery
- quakeholio
Yea on the Wing it is about as easy as they come. Some bikes I have wrenched on you have to be part contortionist to get to the valves.
