Engine removal
Engine removal
Post #1 by Whiskerfish » Thu Jan 29, 2009 9:13 pm
Carbs and exhaust removed previously. Remove any Fairing supports and crash bars and horns now.
Drain Coolant
Disconnect upper hose
Disconnect lower rad housing and seperate from pump housing
Disconnect wiring to Rad fan and overflow hose to expansion tank. Remove Rad Cap and remove radiator. Yes my fan is a bit different. Stock applications you look behind the rad next to the fan for the wiring connector.
Drain Oil, Remove oil filter and Belt covers.
Disconnect Tach Cable and Fuel line, I elected to disconnect the Clutch cable from the bike and take it out with the engine in this situation.
Disconnect Fuel Filter from Fuel Tank and remove
Disconnect Starter hot wire. Make sure to use wrench to hold stud from turning while removing outer nut.
Disconnect the electronic ignition or Point cable wiring.
On a 78/79 you remove this connector to disconnect the engine harness. On a 75-77 you will have to disconnect the wires individually.
Disconnect or cut the three Yellow wires from the stator. (yes mine are red due to a modifcation I did)
Post #2 by Whiskerfish » Thu Jan 29, 2009 9:47 pm
Remove the forward upper bolts and the bolts to the frame for the heat shield. Carefully remove the Heat shield. Ensure to note where the rubber anti chaf gromets go between the heat shield and the frame
It does require some wiggling but it will come out without being bent!!
Remove the upper rear engine hangers. Take care not to loose the long bolt, OEM replacement is liike $26.00!!
Disconnect and remove the rear Brake Switch, then remove Right and Left hand lower engine mount bolt.
Slide the driveshaft rubber boot forward and rotate rear wheel until the snap ring is in view.
Good 90 degree snap-ring pliers are almost a must for this job.
Now slide the boot back and push the drive shaft back along the spline. It will not have enought room to disconnect yet.
Place your support. A Bike Jack works very nice. A floor style car jack also works well
Do a thourough final inspection to make sure all wires and cables are clear and will not snag when you are at a critical point.
Take slight tension with the jack and remove the "removable frame section" from the left side of the bike. The cross bolt may require some adjustment of the jack. When the frame section is gone you need to wiggle the engine out of the mounts on the right hand side so it can move forward a hair to disconnect the driveshaft. If the fuel tank is installed the engine will not have clearance to go up high enough to get clear of the right hand mounts. you need to work it down and forward. It only takes like a 1/4 inch to seperate the drive shaft.
Lower the engine slightly and slide out the left side.
Post #3 by Roady » Thu Jan 29, 2009 11:07 pm
That's very nice, WF. Great pics and well explained. Thank you.
Just a couple of questions ...
Did you do that removal for this writeup, or vice versa?
And, that shirt still fits you? I outgrew mine 20 years ago!
Post #4 by sunnbobb » Fri Jan 30, 2009 4:05 am
Great job Whisker! I would have added the technical language involved during the circlip removal, but this is a family oriented website...
Post #5 by Whiskerfish » Fri Jan 30, 2009 8:41 am
Roady not sure exactly what the question means? I took the pics Wednesday late afternoon when I pulled the engine and did the write up last night.There are quite a few pics I did not use here http://www.ngwclub.com/gallery/v/wingmans/whiskerfish/Engine-Removal If you want to do "you're thing" to this please feel free. I do not have the patience to do what you do :lol:
If you look at the pics I did not use you will see that I had to do some things a bit differently on this removal. The Cross bolt under the engine was seized in the engine. I soaked and beat it for a while then I decided it was easier to just get out the sawzall and remove the opposite side frame.
Sunnbobb
A good pair of circlip pliers takes the need for "technical terms" away :lol: :lol: :lol: :lol: :lol:
ElPiloto
Post #6 by ElPiloto » Fri Jan 30, 2009 9:11 am
It looks to me that the driveshaft snap ring is worn out. Or, is that just an optical illusion made by the flash?
One thing I do when pulling an engine is to inspect every single nut, bolt, bracket etc., to see what needs replacing and what just needs clean up.
Post #7 by Whiskerfish » Fri Jan 30, 2009 9:24 am
ElPiloto wrote:It looks to me that the driveshaft snap ring is worn out. Or, is that just an optical illusion made by the flash?
Actually the snap ring was good. Must a optical Delusion ;) but that brings up a excellent point. For something that is that much of a PITA to change plan ahead and have a new one ready to go! They don't cost much at all and do deform very easily.
Yes under normal situations the very next step would be a thourough cleaning and inspection for damaged or worn components. This one in particular is getting parted out.
roncar
Post #8 by roncar » Fri Jan 30, 2009 9:26 am
Whiskerfish wrote:If you look at the pics I did not use you will see that I had to do some things a bit differently on this removal. The Cross bolt under the engine was seized in the engine. I soaked and beat it for a while then I decided it was easier to just get out the sawzall and remove the opposite side frame.
Sunnbobb
But a frozen bolt adds the "technical terms" back in. Image
Now that everything's out of the way, how about some nice close ups of that centerstand cross member? Maybe with some of a good one for comparison. Thats scary.
Post #9 by Whiskerfish » Fri Jan 30, 2009 9:33 am
Post #10 by Roady » Fri Jan 30, 2009 11:25 pm
WF ... I just asked that because there'd been talk about us needing an engine removal tutorial and up pops yours. Great timing.
I wouldn't touch a thing in your writeup, it's excellent.
peteybug
Post #11 by peteybug » Sat Jan 31, 2009 11:37 am
Great job Whiskerfish, nice pic's. If your parting out I might be interested in that little (bell) hanging on lower radiator hose looks custom to me. Is it to warn critters that are in the road? biggrin Again a great job action1 action1
Sagebrush
Post #12 by Sagebrush » Sat Jan 31, 2009 12:07 pm
Whisker, is this the engine from your bagger? If so why are you parting it out?
sodbuster
Post #13 by sodbuster » Sat Jan 31, 2009 12:43 pm
peteybug wrote:If your parting out I might be interested in that little (bell) hanging on lower radiator hose looks custom to me. Is it to warn critters that are in the road?
Actually those are known as "Rider" bells or "Guardian" bells ....... True Story
http://wapedia.mobi/en/Biker%27s_bell
'06 H-D Road King
'99 Valkyrie Standard - TOTALED :(
'83 GL1100 Standard - SOLD
'82 CB900F - Black & Red - SOLD
Post #14 by Whiskerfish » Sat Jan 31, 2009 7:37 pm
Dean
Yes that is my Bagger. She has been sent off to the happy roads in the sky! I thought about repairing the centerstand support but as bad as that was corroded I was concerned about the rest of the lower frame. Well as it turns out the rest of the frame was solid. I did not find that out until I took the sawzall to it. The engine was tired and the primary chain was making too much noise no matter how tight she was tunned. She had somewhere between 160 and 170,000 miles and it was time to replace her. My Black bike will be my new touring bike wearing the Bagger's "clothing". I have wanted to build a 75 for the street so once this conversion is complete I will start on that. Once the parts I need come in I should have this wrapped up in just a day or 2. All the hard stuff is done.
Peteybug
No that bell was given to me by a special Lady friend to help keep the gremlins off me and my bike. It is something I will always Treasure. It will transfer over to the "new" dresser.
peteybug
Post #15 by peteybug » Sat Jan 31, 2009 8:42 pm
That very sweet Whiskerfish crying1 glad to see you are a sentimental old furt. tumb2 . Glad it was explaned to me what it was. I gotta get one of them :evil:
Who is online
