To test the armature easily, take it to the oldest starter, generator, and alternator rebuilding place. For a few bux, they can test an armature on a device called a "growler".
Test the field windings for continuity.
If you have a good armature, a rebuild is easy. Turn the armature contacts on a lathe and dress down the insulating material between the individual armature contact bars using a hacksaw blade broken in the middle. Use the broken end. Or you could use a jigsaw blade or saber saw blade held with vice grips.
After you have replaced the brushes, pack the bushings with high temperature grease and wipr away the excess after the armature is fitted to the end plates.
Test it with jumper cables before you install it. Don't let it spin for more than a second or two. Then install it.
When you are starting your bike, don't let the starter grind on for more than a few seconds. They are very powerful motors and they get hot quickly. Heat is the enemy of anything electrical or electronic.
A rebuilt OEM starter is better than a cheap new one. (Chinese)
Starter Rebuild
Starter Rebuild
- Lead Member
starter rebuild
if i just need brushes......can i replace them without having the armature tested?....................thanx....mr. Y
mr. Y
Sure, if the starter was working before putting the brushes in.
If you don't have a lathe to clean up the commutator, chuck up the armature in a drill press with the commutator closest to the chuck, and gently clean up the contacts with a sharp file.
While the starter is apart, put a little grease in the bushings. Just a little bit.
- 13 Replies
- 811 Views
Last post by 5speed
- 14 Replies
- 726 Views
Last post by ritalz
- 4 Replies
- 499 Views
Last post by CYBORG
- 3 Replies
- 496 Views
Last post by 5speed
- 2 Replies
- 574 Views
Last post by Sidecar Bob
