Lucky #13 by HOTT
Re: Lucky #13 by HOTT
pretty quick there camper!
- bladredhead
one does appear to be all you can handle.Fred Camper wrote:Wow, why didn't I think of that! I do have my Weber dialed in well, makes a mean buffalo burger. Dual Webers seems excessive, that is a lot of surface area.bladredhead wrote:gaaah... one of these days i'm going to come up with an idea and execute it before someone else does it!
was thinking about dual Strombergs over the weekend if i can't get Webers dialed in.
AHEM!
- HOTT
yeah... sorry about that I could give you all the excuses, but nobody likes a whiner.
I AM getting many Goldwing-ish things done. Wrapping up a carb set-up for
Zach75GL1000 see photo I'll have more on that later under Unique Carbs.
Anyhow, just about through my tandem bicycle events. Be back at Lucky this time next week.
thanks
Ric(slacker)aka HOTT
You cant just show a rear shot of that carb setup!!!!!
- HOTT
Got some beautiful Chrome plated single butted spokes from Buchanan's today.
- HOTT
Took some time to lace up the rear wheel.
16x3.00 chrome deep center.
I scored the 1000 hub on the Bay.
It was part of a nasty wheel that I got for
$30.00. Some glass beading cleaned the stained grunge
and brought back the cast silver look. On to the front...
How did you true the wheel?
- HOTT
I have a truing stand. I haven't done this one yet.
I have to pop bearings back in.
HOTT wrote:I have a truing stand. I haven't done this one yet.
Is the process any different really than doing it on a Bicycle? I was pretty dang good at that a few decades ago but I have never tackled a big rim.
- joedrum
- HOTT
You should try one.WF, I was pretty dang good at that a few decades ago but I have never tackled a big rim.
I find the motorcycle wheels easier and more forgiving. It may have something
to do with the fact that MC stuff isn't so teensy weensy & exotic.
I would recommend to anyone...Take apart an old wheel and try it. It's
just like jumping into a carb repair, hey but no O-rings to loose!
- this is one of our 29" mountain tandem wheels with poly fibre filled spokes.
- DSC_0055.JPG (48.8 KiB) Viewed 414 times
- Dangeruss
. . . . but a truing stand is quite helpful.HOTT wrote:I would recommend to anyone...Take apart an old wheel and try it. It's
Russ
2016 K1600GT
75 GL1000 Project
States visited by Goldwing...
2016 K1600GT
75 GL1000 Project
- HOTT
Everybody Spring Along
Well first, thanks for your patience on this build. It seems the early months of 2013
had other plans for me than Lucky. All's good. Now Let's get after it!
The plan is to give Lucky a springer front end.
"Oo! Lucky's gone be a chopper with a long springy fork."
Well no, but thanks for playing. Actually I'm going 2" Under, ala pre1949 style fork.
....but let's get the basics. Installing a Harley ready springer is relatively easy compared to GSXR install.
I started by removing lower steering stops. the fixed fork section is there on the floor The steer shaft supplied is a 1''dia. (Honda is 1 1/6''to1 3/16''). Bearing fitment can be achieved
turning some simple tube shims. The more industrious may choose to transplant the Honda shaft. Once the fixed section is fitted the top crown can be trimmed to clear the top bearing seal. I traced the seal and used a hole saw to cut through the cast steel crown. 5 photo rule continue.....
- HOTT
...welcome back.
with the crown cut I trimmed the supplied lock bolt/spacer. Here is a quick look sans upper return springs. not torqued down to protect chrome More to follow...
