Rear Shock Rebuild, GL1100I
- CBX n GL man
Re: Rear Shock Rebuild, GL1100I
Yeah, I planned on them being just over 1" shorter.
Just want to know the specs on them and to flush all the crap out. Later.
'81 CBX nekid
'80 GL1100 w/windjammer
'80 CX 500D 1/4 nekid
'84 GL1200A 1/2 nekid -- gone
- 82aspy
might have to go the next step and take 'em apart to get that rightCBX n GL man wrote:Yeah, I planned on them being just over 1" shorter.
ngw quotes - \ "I will strip the beast" \ "the swingarm is just a hunk of metal" \ "gonna maybe ...dunno yet" \ "It's never done, thats the fun." \ "something about this site brings me back"
- CBX n GL man
They're already apart but just waisting fluid by pouring in and slowly cleaning out crap. Would engine cleaner have any negative effect inside there.
As far as part #, online I see two for the same part. Later.
'81 CBX nekid
- fish
Re:
I feel like I have heard this beforeolered67 wrote:I just got VU JA DE!!! That's like DE JA VU except its an overpowering feeling that you have never been here before!!!
I guess it wasn't VU JA DE but DE JA VU!!!
Timothy Mark Fisher
Catalina Arizona
Catalina Arizona
- 82aspy
i mean complete disassembly, its the only way to check internal partsCBX n GL man wrote:They're already apart but just waisting fluid by pouring in and slowly cleaning out crap. Would engine cleaner have any negative effect inside there.
- CBX n GL man
Can anyone verify amount of fluid needed in Gl1100 shocks, thx. Later.
'81 CBX nekid
- rod willis
according to the book I have they call for 365 cc or (12.5oz)
of ATF oil for each shock this is for the 80-81 hope this helps
Rod
Rod
rod willis
1976 GL1000
1976 GL1000
- CBX n GL man
Thanks Rod. Later.
'81 CBX nekid
- Rusty Probie
I have my rear shock apart following the instructions. every things is going well. But I am confused as to where the spring wire ring shown in the picture goes. The parts are- internal snap ring washer, seal, thin washer, bearing and spring wire. The parts are listed as they came out except for the spring wire. it expanded and slid over all other parts. Again where does it belong.
- mildhog
- Zinc Member
If you forget the fluid, , here's another way to fill the shock. Attach the air hose and immerse the end in ATF. Compressing/de-compressing the shock will suck it up. That's how it's done on the GL500 monoshock.
Arnie in VA
In the stable:
81 GL1100, 82 GL500I, 83 GL650, 81 Gl500I, 82 GL500
In the stable:
- tbpmusic
How does one accomplish "complete" disassembly - meaning further than the seal replacement procedure?82aspy wrote:i mean complete disassembly, its the only way to check internal partsCBX n GL man wrote:They're already apart but just waisting fluid by pouring in and slowly cleaning out crap. Would engine cleaner have any negative effect inside there.
The FSM makes no mention of anything other than that.......
It's never straight up and down.
Bill Lane - '71 CB450 half-breed, '71 C70M, '75 CB200, '81 CM200, '73 CL350
- 82aspy
basically you have to set up a jig,
folks usually make it outa wood, along with nuts/washers/a few foot long threaded rods combo,
to secure the shock and then unscrew it to get inside,
info/pix are out there
- calif wingnut
Oem 1100/1200 air shocks look the same until one looks closer. Everything measures the same less the 1200 shafts/rubber boots are 1" longer.
When you see scoring on the chrome shafts like these, they are toast.
- IMG_5404.JPG (95.63 KiB) Viewed 462 times
- IMG_5403.JPG (95.4 KiB) Viewed 462 times
- IMG_5402.JPG (113.49 KiB) Viewed 462 times
- 82aspy
they can also come apart while riding, due to rust fatigue on the outer shell
