some comments about the standard point ignition
- mikenixon
- Early 'Wing Guru
This is not the best venue to say what could be said (and I already have said a lot elsewhere) but one basic thing comes to mind as I look over the material I have assembled to produce another Motorcycle Project how-to booklet.
The one thing I want most to say is how crappy non-original points sets are! Honda used only TEC (Toyo Electrical Co.) and ND (now known as Denso) for original equipment points. The aftermarket does not serve us well. Why? They're junk. I could go on about how nearly impossible Diachi points are to dwell, how inferior their contact surfaces are, and much more. But let me simply show a couple of pictures. Granted these are SOHC examples and not Gold Wing, but they illustrate the Diachi manufacturing ethic nonetheless.
Following is the stock TEC. Note the smoothly machined pivot post, and the presence of a thrust washer.
Now the Diachi example. Roughly machined and no thrust washer. Telling, this, don't you think?
Now let's look at the corresponding surface on the pivoting arms. First the stock example. Note the brass insert, a kind of bearing for the pivoting contact arm.
And the Diachi points. No insert, the arm runs right on its insulating phonelic material.
Bear in mind this is just the beginning. Lord willing I will have both articles on my website and a how-to booklet sometime this year detailing more about this issue.
Mike Nixon
www.motorcycleproject.com
https://youtu.be/CDnzwDWhN24
Re: some comments about the standard point ignition
Very nice, As someone that enjoys tuning very much I look forward to reading the whole thing!
- mikenixon
- Early 'Wing Guru
You do, don't you? I have heard you referred to as the carb sync god.
Mike Nixon
Nice facts there Mike. Very good.
I certainly would not go that far but to me the tweaking toward the end of a project is the most rewarding. I learned tracking and balancing of Helicopter rotor systems (considered by some a Black art similar to tuning) from a Master decades ago and I think that is where the tuning bug comes from. A small adjustment here must be countered and softened over there type of thing. People under estimate what good tune can do.
- mikenixon
- Early 'Wing Guru
Well put! Yes, in this area little things do indeed mean a lot!
Mike Nixon
- Toehead
As a mechanical engineer, I can tell you that that thing was designed by the finance department.
- salukispeed
Nicely said Mike
There are many things that OE can be the better quality even at the higher price. There are always the exception and places to save money.
When it comes to tinkering and tuning I was always reminded as a young man that "everything affects everything". and the devil is in the details. their are probably lots of sayings and words of whisdom that reflect this.
- Toehead
Also notice the grease reservoir on the stock points.
- mikenixon
- Early 'Wing Guru
Yup.Toehead wrote:Also notice the grease reservoir on the stock points.
Mike Nixon
- fish
I have never replaced a set for exactly this reason.
Carefully polish and clean W/ fine emory then 600Grit sandpaper
IMHO the important thing is to clean off all the grit from the abrasives B/C the are semi conducters/.
- El_Taco
I've never bought a set of points, I'll just buy another low mileage junker and cob them off of that. A little clean, a little shine, and a little gap. A little vroom.fish wrote:I have never replaced a set for exactly this reason.
I must admit I don't set them with a dwell meter, nor do I set my timing with a light. One of these days, I'll break down and do it right.
- El_Taco
My edit button disappeared. Can you post us a part number for the set, or numbers for the respective parts?
This could be worth investigating as to whether or not Standard carries them. Considering I get the average set of points for about $6, I could post some pictures to further add to your comparison.
I would consider Standard to be mediocre, but useable. At least, they should line up, maybe with a hint of persuasion from the right pair of pliers. I replace a set of points every month, sometimes several, mostly on early Ford and Ferguson farm tractors. Standard parts tend to go right in.
A&I is our ag/industrial parts supplier, and they sell the cheapest no label (long string of expletives) that I imagine anyone could export out of third world countries. When the contacts don't even come close to each other, or the breaker arm is made from plastic, and distorts in the packaging, you know you've got some real nice stuff. Countless times I've had to make do with the stationary contact out of the box, combined with a good enough factory Ford breaker arm from the 40s. If it's made from Bakelite, it's still good.
Of course, they also sell pump parts that fit the pump, but then the pump doesn't go back in the machine. I can't even imagine how many times I had to grind the corners off of new valve chambers before lapping in original valves with a special tool on the original guide, because the aftermarket internals weren't worth trying to use.
Oh, the joys of the aftermarket.
Honda still sells the entire plate built up with both sets of points for about 48 I believe. As often as I find them with buggered up screws this is one of the things I keep on the shelf.
Stock
Left points 30204-292-003
Right points 30203-292-003
Plate assembly 30200-371-004
those are the stock Honda part numbers not the upgraded points as recommended by many.
Stock
- mikenixon
- Early 'Wing Guru
Yes, but Whisker, aren't they "pattern" parts, i.e. non original? I believe Honda is selling Diachi now.Whiskerfish wrote:Honda still sells the entire plate built up with both sets of points for about 48 I believe. As often as I find them with buggered up screws this is one of the things I keep on the shelf.
Stock
Mike Nixon
- 6 Replies
- 319 Views
Last post by BlueThunder
- 7 Replies
- 257 Views
Last post by RB
- 7 Replies
- 227 Views
Last post by sunnbobb
