Adapting Rear Master Cylinder from GL1800 to GL1100
Re: Adapting Rear Master Cylinder from GL1800 to GL1100
Most of the time anything you want to do, or is worth doing, is worth doing right. And is always more complicated then you first thought. But there's the fun of it action1 action1
Yes sir.
Think I am getting a little better picture now. 1980 1100 has a rear brake line with banjo fittings on both ends. Might be time to de-link the 83.
u093905
Lead Member
Lead Member
Post by u093905 »
Great tip,just did it. Very straight forward. Thanks
adecood
Post by adecood »
I just saw this post on swapping out the rear master cylinder w/ one from a 1800. I too am trying to look at ways to improve the breaking performance on my 1200. And this sounds like another option. So one question I have is seeing that the 1800 has a larger piston which should translate into more force. Are there any modifications that need to be made to the caliper asm's. When you made the switch did you also rebuild the calipers w/new bushings. I am not a hydraulic eng so I am wondering can the rest of the system support the increased force from the new master cylinder? Seeing that this post started a while back I am wondering can someone post a follow-up on the real world effects of this rebuild. That would be nice to know seeing that the breaks are pretty important feature on the bike.
Dave D.
84 1200 GW Std
02 1800 GW
82aspy
Post by 82aspy »
i haven't seen this done (or run across info) on stock 1200 linked brakes, or 1200 period, could be someone did tho,
i think the 1200 rear m/c uses a built in splitter (for one front & one rear caliper) so going 1800 rear m/c would prob work but only if intending to unlink the stock linked 1200 brake system/setup, which many do,
mounting would have to be sorted if doable, or how complicated it might be to go there, haven't seen info on that
turned out pretty easy for 1100 setups, however, the 83 1100 is linked but the rear m/c uses an external remote splitter,
pretty sure at least one 83 has gone with the 1800 m/c and don't recall mention of unlinking so could be for 83 only, easy to go eitherway
mhynze
Post by mhynze »
What about a 76 GL 1000 ? Will this work on that? I'm in middle of a build
1977 GL1000, with GL1100 engine and carbs....in progress
1984 GL1200 Ascenpade gone naked...............in progress
1976 GL1000 1200 Engine, 1200 wheels...........in progress
1983 GL1100 Stock, fully functional!
1982 GL1100 ..................................................in progress
1976 GL1000 Stock resto....................... .........in progress
1978 GL1000....Upgraded...Bad cylinder............in progress
1982 CB900, 83 GL1100 rear end, 2006 gsxr1000 front end, 1200 front wheel..... in progress
1981 CB750k Needs attention.... in progress
The more time I spend on here the farther behind I get
82aspy
Post by 82aspy »
mhynze wrote:What about a 76 GL 1000 ? Will this work on that? I'm in middle of a build
might not be a big issue but, haven't seen info on that, or concerns finding good used, which was a big issue for the 1100 line
steve.o
Post by steve.o »
Anyone know how i can save this post as i just spent 2 hrs looking for it !
thanks steve.
82aspy
Post by 82aspy »
you can save it (the url) as a favorite/bookmark in your browser, or
you can save it in your profile on this site by selecting 'bookmark topic'
if you point on the wrench icon/button you will then see a 'topic tools' indication,
when you click on it, a drop down menu shows up,
the wrench icon/button is to the right of the 'post reply' button, which is on the left of each page at the bottom or underneath a post or thread
steve.o
Post by steve.o »
Thanks! i just ordered one of ebay !
but after buying it, the add says for fuel injected model, will this still work on my gl1100 ? or are all master cylinder same ? thanks again,
:IDTS: :IDTS:
Just to add to the pool of knowledge, I did this upgrade to my 83 and unlinked the brakes. Simple on the rear brake, removed the splitter and used a rear brake line from an 80-82 1100. The front brakes I used lines from a 80-82 and a splitter. I did replace the front master with MC for dual calipers. The lines could stand to be a bit longer and I plan to replace them as funds allow. Overall braking improved.
Buli
#28
Post by Buli »
Hello. Here has been a debat how bigger brake master cilinder piston increases brake power. IT DOES Not. When master cylinder diameter increases u need more pedal force to get same brake power. So when u swap 1800 master to 1000 u get less brake power. In this case u only hafty press little harder rear brake pedal. But it is good to know. Great post anyway
Kinde
Easter
#29
Post by Easter »
Sorry for the delay in answering some of the questions about this swap. I haven't kept up with the comments.
I have now been using this for three years and am completely satisfied that it is as good as stock. As someone said the used 1800 MC can be had for about the same price as a kit for the stock MC. I would imagine there are other MC out there that can be adapted in the same way.
Yes you do need to switch brake lines. I was switching to stainless anyway so I didn't give it much thought. :crosso
83 GL in process :IDTS:
dougeferguson
Rusty Probie
Rusty Probie
#30
Post by dougeferguson »
Just found out that my 83 GL1100 master cylinder needs replacing. How did you fix the problem with the hard line flare fitting on the old master cylinder verses the new banjo bolt connection on the 1800 cylinder?
