Customising my first Goldwing
- Sugs
Re: Customising my first Goldwing
You can check out my thread and take a look at what I've done to my seat for some ideas, scroll to the bottom. http://www.ngwclub.com/forum/viewtopic.php?f=16&t=57962 I started using a belt sander with coarse grit to get it where it is now, it does get thin real quick on the sides so go easy. Still have to get it covered but haven't had much time lately to work on the bike, will get to it eventually.
_______________________
'79 Honda GL1000 Goldwing
Fitted my new cam belts this weekend, slightly scary but it all turned out good and the engine runs smoothly.
Seat is on hold while I decide on wether to trim the plastic sides down to get a narrower seat.
Got a Triumph seat off ebay for the princely sum of £1.20 ($1.74) +£8 ($11) postage so even if I get it completely wrong it will not matter much.
Question is...where do I cut the front to make it fit?
- wingrider
Good price on the seat! If I remember correctly, Octane showed the cuts he made when he was building the Bulldog. Have to look into that myself, as I have one to hack up too!
- wingrider
About the best picture I could find is in the first page of one of Octane's threads...bit down the page located right here.
Iv been looking at some new shorter shocks for the bike and found some in my local shop. Unfortunately it doesn't say what bike they are for but heres the specs.
Are these strong enough for a gl1100 with pillion
Dimension:
Total Length:315mm (12 3/8")
Length of Eye to Clevis Eye Core:280mm (11")
Clevis Hole Diameter: 8mm
Clevis Inner Width: 20mm
Clevis Maximum Tensile Strength: 2,000 Kgf
Spring Thickness: 7mm
Spring Width: 60mm
Spring Stiffness: 110 kg
Maximum load: 150kg (≈330 lbs)
Air Reservoir: Adjustable
Factory Air Pressure: 0.4 Mpa
Maximum Air Pressure: 0.5 Mpa
Dimension:
Spring Width: 60mm
My seat is coming along nicely, took it to a local car seat company. Oxted Trimming Co. in Oxted, Surrey. UK. They make all the seats for the Caterham range of cars in the UK so they know what they are doing.
So, this is the final shape and it will get covered this week in a nice vintage style distressed brown vinyl with diamond stitching.
You can also see in the fist two pics that I bobbed the rear mudguard
Hope ya like it
Hope ya like it
Brown seat on a black bike???
To be painted laterCYBORG wrote:Brown seat on a black bike???
Looks awesome.
- 230Rocket
Andy,
Looks like your seat came out really good, I screwed up a little by cutting too much off the baseplate at the front where it needs to meet the tank and subsequently I then took too much foam out. Luckily these seats aren't rare so I have another to play with. Do you have any additional pictures of the foam or baseplate cutting you did? I'd like to follow similar lines of yours.
Great job on the whole bike, it's good to see the vision coming together.
cheers
Dean
cheers
Dean
1982 GL1100 Fat Turtle
I didn't take any pics after but I made these cuts, about 5mm off the bottom edge and the other two cuts to shape it
And rounded off the back edge a bit more.
When I get the seat back Ill take a few pics for you.
- 230Rocket
superb! exactly what I shoulda done! I'll keep an eye on things here...
cheers
Dean
cheers
Dean
- Steevensi
Do you have pictures of your new seat??
The Black Bike
http://www.ngwclub.com/forum/viewtopic.php?f=30&t=59312
1982 GL 1100
1980 GL 1100 to be fix
1983 Honda Nighthawk 650 sold
1982 Honda CB 750 K under construction
1980 Suzuki A100
1974 Suzuki TS 250 sold
1992 Yamaha RT 180 sold
1976 Honda CB125 sold
2002 Suzuki Katana 750 sold
1983 Suzuki GS770 rusting in a shed
1982 Suzuki GS750 in boxes
1982 GL 1100
1980 Suzuki A100
- 12 Replies
- 1114 Views
Last post by rjdoles
- 8 Replies
- 759 Views
Last post by chunk
- 11 Replies
- 548 Views
Last post by redwood
- 5 Replies
- 770 Views
Last post by Rat
- 22 Replies
- 4589 Views
Last post by AZNGW Rider
