Handle bars for an 85
Just realized today when my new bars arrived that the 85 (at least the dressers) have One inch bars. Further complicated by reducing to 7/8 for the controls and grips. So anyone know of a nice low rise bar with both one inch center and 7/8 at the outer ends? OR--some other solution?
Re: Handle bars for an 85
I've seen 7/8" bars shimmed to fit in 1 inch clamps...
- OhioBill
- My Album: http://www.ngwclub.com/gallery/v/wingmans/OhioBill
I used the shims when I put the 1200 forks on my 75.
OhioBill
Retired and Loving it.
1979 Black (to be restored)
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
- Sugs
Renthal Fatbar maybe, but it says the clamping area is 1-1/8" or 28.6mm. Not sure if that would work for you.
_______________________
'79 Honda GL1000 Goldwing
Thanks all, guess I will try the shems.
- salukispeed
Will some strips of 1/16 aluminum rolled into four pieces to fill the gap very much like crank bearings work? Be sure to put the top clamps on the correct way and tighten the front bolts first then the rears to finish the clamp forces. I believe there are dots that identify the front side. the gap is always at the rear on these.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
- 9 Replies
- 412 Views
Last post by tomk1960
- 4 Replies
- 307 Views
Last post by Funkdoctor
- 3 Replies
- 962 Views
Last post by robin1731
- 6 Replies
- 759 Views
Last post by Oldmopars
