Combining a 77 and 78 engine to make one.
I have a 77 gl1000 engine that had a broken ring score up the cylinder wall. I also have a 78 engine that appears good. (I have not opened it up yet to check it out though)
I know to use the cams, upper valve train and carbs from the 77, but is there anything else I need to swap over? Thanks- Slim
1977 GL1000, 1200 transplant, sold
1976 GL1000
1975 CB360T(in the family since new and restored)
1975 GL1000
1974 CB360
1961 T20 Tiger cub SL
1959 T20 Tiger cub S
03 Shadow Spirit 750
1976 GL1000
1975 GL1000
1974 CB360
- ritalz
Re: Combining a 77 and 78 engine to make one.
The rear engine cover if you want to retain the kick starter.
Yea, that's already on the list. Are the timing marks on the cranks the same?
1976 GL1000
1975 GL1000
1974 CB360
1976 GL1000
1975 GL1000
1974 CB360
- wingrider
The timing marks will be slightly different between the two years.
Ignition timing marks have five degrees difference. 75-77 is 5 BTDC and 78-79 is 10 BTDC.
Mechanical advancers are different, keep the one with the 77. (371)
I think I'll swap the crank assemblies to keep things where they should be.
1976 GL1000
1975 GL1000
1974 CB360
1976 GL1000
1975 GL1000
1974 CB360
That makes it a pretty big job. If you want the five degree mark, just cut the distance between T and F in half. Others here have used a chisel to score a line in the crank.
- pierce
- My Album: pierce
I think using the earlier crank and pistons, the whole shebang is a good idea. The end of the 77 crankshaft has the addition of the Kickstart mechanism. Not just the rest case.
I would also switch out the tensioner to the 1200 to reduce chain rattle.
If you are fairly mechanical, and time to yourself shouldn't take more than a day with prep.
Complete gasket set, ebay 120 maybe. Order used tensioner off eBay, a few dollars. Oil, oil filter, plugs and new coolant , belts and permatex gray to seal the case. Good to go for around 200.
See you in a few hundred thousand mies.
1976 GL1000
1978 Gl1000
1978 Gl1000
I already have the 1200 tensioner and will be taking some of the winter to get the job done. Im also thinking of getting the valves and valve guides done in the 77 heads for piece of mind. Thanks guys!
1976 GL1000
1975 GL1000
1974 CB360
1976 GL1000
1975 GL1000
1974 CB360
- delling3
Not wanting to hi-jack this thread, but I have a question reflecting my ignorance here. If the idea is to swap the crankshaft from engine 1 to engine 2, do you use the bearing shells from the donor engine, or the destination engine? Does it matter? I know that there are different bearing sizes. Is the size based only on the crank, or just the crankcase, or both?
delling3
1979 Yamaha XS750SF
Previous:
2006 Kawasaki Concours: Sold
1979 Yamaha XS750SF
Previous:
The "size" is in every engine. Back in the day called blueprinting. Both crank and rod bearings are Matched to the block and the crank. By color of the bearings. The difference in size from color to color is very small,......but different. The marks on the block are the factory determined colors for each block/crank combination.
Just changing a crank and block combination from one engine to another might work, as the differences between colors is very small, but defeats the original intent of the factory, and could limit the life of the engine
If bearings were readily available in all colors, a factory fresh engine could be built. But in my experience, they are not. If you can find a source for all different color bearings, let me know. I have been looking for a long time
A whole lot easier to just mark the crank you have.
Even if it all took the same bearings it would be a lot easier to mark the crank. Swapping it all out is a lot of work just to have the timing marks in the correct location.
I measure out engines when I pull them apart for rebuild to see what it will need. I will use plastigauge to check the crank bearing clearance and go from there. I would like to retain the kickstarter if possible, but if things don't measure up in the swap, then I'll just have to do without. ( not a deal breaker, just love the idea of a kicker)
1976 GL1000
1975 GL1000
1974 CB360
1976 GL1000
1975 GL1000
1974 CB360
- delling3
From my first reply, I know that engine bearings are basically unobtainium. Once you pull a motor apart and start into plasticgauge, the assumption is that you can get bearings. Not so (at least for now) with 4-cylinder wings. I would lean towards using the bottom end of your donor engine as-is. Unless you have already confirmed that it needs a full rebuild. Then I might start looking for another donor. That's me, YMMV. I had a '76 with a kicker, and now have a '78 w/o. I would prefer to have it (for emergency use), but on the 'Wing they ain't very user friendly, and I don't think I would tear down a motor just to have a kickstarter. I would simply swap the top end/valve train, and mark the flywheel. Robin and Cyborg are far more experienced than I, and unless I mis-read their replies, I think they agree. In any case, good luck with your project!
delling3
1979 Yamaha XS750SF
Previous:
1979 Yamaha XS750SF
Previous:
