Oil drain plug thread engagement?
chrisz
Post by chrisz »
Hi all,
Was changing my engine oil and when torquing the drain plug with the torque wrench (27 ft-lb) the threads on the sump side stripped out. I've ordered the Time-sert to make a new and more lasting repair, however as I'm waiting for the equipment to arrive I've made a temporary fix to allow me to keep riding. I saw that the stripped hole still had good threads at the back end that never made contact with the original plug/bolt. My temporary fix was to obtain a longer bolt (2 inch in this case) with the M14-1.5 thread and cut this bolt down to be slightly longer then the original oil bolt to engage these never used threads. So my question is, I have about 3-4 thread engagement (including a new washer) tightened up (without a torque wrench), there are no leaks with the engine running for a few minutes. There shouldn't be any great deal of pressure in the sump, are there any concerns with my temporary 'fix'?
flyin900
Re: Oil drain plug thread engagement?
Post by flyin900 »
There should be no problem but I would keep an eye on it for any leaks.
FYI the torque spec is pretty high for both the oil drain plug and the oil filter bolt and I have longs since given those spec's a pass for the reason you have encountered.
I feel 15 ft lbs is more than enough to keep the two bolts snug and not create any issues with stripping t
Current Bikes:
jdvorchak
Post by jdvorchak »
The auto parts stores sell rubber plugs to use in stripped drain plugs. I've had one on my Hyundai for several years with no problems.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
RIP: cookie
If you have a good crush washer you don't need anywhere near that much torque .... :shock:
I go finger tight and then maybe a 1/4 turn with a wrench ....
RAT wrote:If you have a good crush washer you don't need anywhere near that much torque .... :shock:
+1 on this...
chrisz
Post by chrisz »
Thanks guys for your input! I now feel a better riding the bike. I was worried about loosing the plug and having oil spew out on the road, coating the rear tire and making things interesting.
+2......the washer does the work. Use a new one when you change oil
