1984 Interstate Extreme Basket case
- Rednaxs60
Was allowed to view an '84 Interstate (confirmed by viewing the OEM tally plate on the steering stem) basket case this that will be coming up for bids – a repossession by a local Bailiff friend of mine.
It is strapped onto a small roll pallet and is in a state of tear down such that I could not find some of the important pieces. Unfortunately if it is not bought at the auction it will become scrap metal.
Not a lot that I can use a lot of the items, but there are 3 side mirrors in good shape, the rear rotor is the same P/N as the one for my bike – need one for the bike in Ontario, the front rotors as well. Could not find the exhaust headers as the left one if in good shape is needed. The front forks are the same for the '84 to '87 years - found that the front fork upper tubes on my '85 here in Victoria could use a change.
The person that owned it was trying to fit Aspencade fairings to the bike. Know this because the front fairing is from an Aspencade and has the digital dash. Did not get a look inside the saddlebags, should have. There was no rear trunk either. Found the intake manifold, but only one carb was attached.
Had the side chrome panels – both, the fuel pump chrome cover was in good shape. There is a windshield in good shape as well. there were a few other small pieces that would be good.
I think a bid of $25.00 would get this basket case. Take off what you need immediately and say goodbye to the rest. I do not have a storage spot for this, nor a trailer to move it.
Considering a used rear rotor is a minimum of approximately $65.00 USD the cost would be justified.
Going to ask my friend if another viewing could be done and what the process is when an item is bought.
Cheers
Cheers
2021 Royal Enfield Himalayan
- wingrider
Re: 1984 Interstate Extreme Basket case
Does that have an engine? Would be worth it if so.
- Rednaxs60
Has an engine. Thinking that just about everything not being used or kept can be recycled. Carbs as metal scrap, wiring, electronics, tires, rims can all be recycled. Would give me a couple of days to go through the mess. The engine cannot be used by me in an '85 LTD fuel injected bike and it is an '84 engine. The valve covers are in better shape than mine so a swap would occur.
Cheers
Cheers
- wingrider
Was thinking you could sell the engine and make out good.
- Rednaxs60
Good idea, but the shipping would be quite expensive I would think. Have not ruled out putting in a bid, a few things that would be good for me to keep. Would be a week project to itemize and determine what to keep or throw in the recycle. Small market here on Vancouver Island.
- desertrefugee
There's no reason an 84 engine could not be adapted to the later fuel injection. Aside from the ignition pulsers, it's the same motor. Pulsers can be installed up front on an 84 motor.Rednaxs60 wrote:Has an engine. Thinking that just about everything not being used or kept can be recycled. Carbs as metal scrap, wiring, electronics, tires, rims can all be recycled. Would give me a couple of days to go through the mess. The engine cannot be used by me in an '85 LTD fuel injected bike and it is an '84 engine. The valve covers are in better shape than mine so a swap would occur.
Cheers
- Rednaxs60
Thanks for the reply. It gets one thinking and looking into similarities so a possible good solution can be found.desertrefugee wrote:There's no reason an 84 engine could not be adapted to the later fuel injection. Aside from the ignition pulsers, it's the same motor. Pulsers can be installed up front on an 84 motor.Rednaxs60 wrote:Has an engine. Thinking that just about everything not being used or kept can be recycled. Carbs as metal scrap, wiring, electronics, tires, rims can all be recycled. Would give me a couple of days to go through the mess. The engine cannot be used by me in an '85 LTD fuel injected bike and it is an '84 engine. The valve covers are in better shape than mine so a swap would occur.
Cheers
The two items that come to mind are the Ns sensor installed on the crank shaft in the timing belt area, and the Gr/Gl sensors installed on the rear of the right cylinder head camshaft.
The Ns sensor would not be a problem, just need the multi-tooth trigger wheel for timing.
The install of the Gr/Gl sensor is a little more involved. The right camshaft for the fuel injected model has a different P/N. I think it has been modified to accept the sensors - the end of the camshaft has been drilled to accept the sensor assembly bolt. A swap of the right camshaft, or refurbish the '85 heads and install. I checked the left camshaft for the '84 engine against the '85 FI engine and it is the same.
Checked the piston con rod and the cylinder head assembly for both '84 and '85. These are the same P/N so the distance between intake ports on these engine should be the same, and as such the FI manifold should bolt up to the '84 engine.
The stator and power requirements for the '85 FI is significantly larger than the '84 Interstate. The '85 FI operates at approximately 22 to 25 amps normally. This is approximately the max output of the 350 watt stator on the Interstate. Would have to consider upgrade to the "Poorboy" alt mod to make this engine work - not a big issue but a consideration.
The gear shift indicator switch is slightly different as well. Would have to investigate further.
Can't think of much more at this time, but probably will have more questions before I have to make a decision.
Front and rear wheels are the same for these two models as is the final drive.
There are a lot of good possibilities with this find. Being able to refurbish say the FD with new seals etc and then just do a swap is beneficial.
Would seem when you analyze the issue that there are a lot of parts that can/should be usable between the two years and models. The frame, probably not, and it requires a lot of storage space; however, if one were to do a frame up restoration of the '85 FI model, if the '84 frame was compatible you would be into a swap scenario.
Many possibilities, but I still have a storage issue.
Cheers
- desertrefugee
Forgot about the stator. '84 uses a different starter, as well. That one bit me a few years ago.
- Rednaxs60
No worries. Putting an external alternator is not an issue, works well. Have already done one, will be prepping the mounts for a second install. Gets easier as you do more. The starter can be rebuilt, should work for a few more years if so.
You gents don't make this any easier. You're supposed to tell me I'm crazy and run, not walk, away.
- desertrefugee
+1 on the Poorboy conversion. I did one on my '84 and it was the best "upgrade" I ever did. I did a full write-up on the project on the Steve Saunders site in 2010. Not so good for a Standard, but perfect for the Aspy/Interstate.
- 8 Replies
- 391 Views
Last post by duke182
- 8 Replies
- 410 Views
Last post by Liam
- 40 Replies
- 2712 Views
Last post by MikeNTexas
- 13 Replies
- 617 Views
Last post by Easter
