1985 GL1200 Limited, time for a new project.
Re: 1985 GL1200 Limited, time for a new project.
Looks good so far.
You know you can out more than one picture in a post.
- Wolfie666
No, going to use dual Webers.
Don't take life seriously,
You will never get out alive!
- Wolfie666
With the lights.
-The fender is a "Twisted Choppers" 7 x 16 that I sectioned to fit the 150/90 15 Avon Venom Tire.
- Wolfie666
The electrics tray, radiator catch tank, and the upper front engine mount and partial shield (to keep the heat from the carter fuel pump which will sit directly behind it.)
and maybe the battery box...
- Wolfie666
Tacked up the exhaust...
Modified the air scoops from an 1100, moved the 1200 tank forward to make room for the
Mustang early sportster seat. Had to cut back on the turning radius of the forks.
Still have to open up the rear of the "tank" so the seat fits inside...
- codyjames707
Man, this is looking like a quick build with good quality! Keep it moving! Are you moving the air filter for the carbs to the outside of the frame??
- Wolfie666
Using dual Webers.codyjames707 wrote:Man, this is looking like a quick build with good quality! Keep it moving! Are you moving the air filter for the carbs to the outside of the frame??
- BikeMaine
When I first saw your rear fender welded before the primer, I thought it wasn't going to look good at all, but then the photo with it all primed changed my opinion completely. Very nice.
And Welcome to the Forum!
Kevin
1982 GL1100A
1982 GL1100A
- codyjames707
Looking forward to seeing more progress!
- Wolfie666
I did the rear fender like that so there wasn't so much space between fender and bags.
Progress as of today, getting ready for paint.
- Wolfie666
Imitation Tank ready for paint
- Wolfie666
Little progress...
That be red! Gonna look good!
- BikeMaine
I'm looking forward to seeing this put together.
Kevin
1982 GL1100A
1982 GL1100A
- Wolfie666
Waiting on paint for the tins, frame and the engine.
Working on some of the electrics. I use Motogadget's M-Units for all my bikes,
and that makes it simple... But I can't leave anything alone so getting carried away with electrics...
- 75 Replies
- 22924 Views
Last post by Rednaxs60
- 12 Replies
- 725 Views
Last post by Lucien Harpress
- 5 Replies
- 940 Views
Last post by Old Fogey
- 5 Replies
- 604 Views
Last post by Honda_Recycle
