C5 ignition
- millerdog
C5 ignition
I’ve recentl purchased a C5 ignition with the thin coils they offer. They state on the website that they will mount on an 1100, but are pretty vague on the 1000. Anybody have any problems with mounting the coils on a 1000? They claim plug and play, but I know from experience, this is not always the case. I’m just wondering if I’m gonna need to do some fabrication, or not! LOL. Super excited about this. I’ve had about every ignition you can think of on this bike. Not completely happy with any of them. Looking forward to seeing the difference. Thanks in advance!!
Re: C5 ignition
not sure what coils you are talking about, but I mounted the coils that came with mine, ignoring the directions, and the traditional mounting place, to find another spot that they would mount and the wires still reach. Works fine. I don't see why theynhave to be mounted any one particular place
- BlueThunder
Re: C5 ignition
The included coils do fit on the GL1000. Its a little tight and I had to remove the air filter housing. No fabrication was needed. However, I found that it is MANDATORY to use a relay to power the coils. Wiring through the RUN switch did not provide enough current and the C5 sputtered above 3500 RPM. The relay solved the problem.millerdog wrote:I’ve recentl purchased a C5 ignition with the thin coils they offer. They state on the website that they will mount on an 1100, but are pretty vague on the 1000. Anybody have any problems with mounting the coils on a 1000? They claim plug and play, but I know from experience, this is not always the case. I’m just wondering if I’m gonna need to do some fabrication, or not! LOL. Super excited about this. I’ve had about every ignition you can think of on this bike. Not completely happy with any of them. Looking forward to seeing the difference. Thanks in advance!!
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- millerdog
Re: C5 ignition
Thanks for the tips! The relay has me worried!
Re: C5 ignition
+1 on the relay. It solves a lot of problems. I use the run switch to switch the relay.
Re: C5 ignition
I'm not sure what you mean by the "thin coils" either, but I mounted mine on an `82 1100 and they weren't exactly what you'd call plug and play. The relay must be a GL1000 thing, because I didn't need to. Or maybe I should, perhaps I'm missing something! What do I know? I'm certainly no expert.
If parts ever become a problem you can get ahold of Scott Campbell. Power Arc Ignitions. Inc. 2518 NE 102nd Ave. Ankeny. IA 50021. 515-964-7608. http://www.powerarc.com He'll fix you right up.
Re: C5 ignition
I don't know if I used a relay or not. Probably did. I got relays controlling everything else. But it works so well, I haven't had to look at it in a couple of years
- millerdog
Re: C5 ignition
I sent them an email, asking about the power requirements, and using a relay. Hopefully I’ll hear back soon!
Re: C5 ignition
- millerdog
Re: C5 ignition
Mine hasn’t actually arrived yet, but yes, I believe that’s the one. With the mc2 coils.
- AussieGold
Re: C5 ignition
this is a pic of one of mine .GL1000. in place of stock. not sure if it is the same coil pack you have purchased, but fitting is simple. it will be the best single upgrade you could do, in my opinion. i am sure Paul from c5 is available for any issues you may have.millerdog wrote:Mine hasn’t actually arrived yet, but yes, I believe that’s the one. With the mc2 coils.
ps
the relay is nothing to be afraid of, very simple to fit.
Mentor to all self appointed (and genuine) GURUS.
An LTD is........it just is.
- BlueThunder
Re: C5 ignition
They told me that one wasn't needed. Boy, were they wrong. Take the time to put one in, you will be happy you did down the road.millerdog wrote:I sent them an email, asking about the power requirements, and using a relay. Hopefully I’ll hear back soon!
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
Re: C5 ignition
BlueThunder wrote:They told me that one wasn't needed. Boy, were they wrong. Take the time to put one in, you will be happy you did down the road.millerdog wrote:I sent them an email, asking about the power requirements, and using a relay. Hopefully I’ll hear back soon!
They do test their ignitions before putting them out for sale. If the manufacturer tells me it doesn't need a relay I'm going with that. You are the first I've heard of that has had this issue. Where did you get the power for yours from? Originally? We are talking about 40 plus year old wiring afterall.
Re: C5 ignition
The relay assures full battery voltage to the unit. So does GOOD stock wiring
Re: C5 ignition
Obviously I know what the relay does and is always good practice. But if their testing shows it isn't necessary then I would believe that. Like my earlier post mentioned we are working with 40m year old wiring if it hasn't been updated.
- 0 Replies
- 270 Views
Last post by gltriker
- 7 Replies
- 358 Views
Last post by desertrefugee
- 74 Replies
- 5611 Views
Last post by CYBORG
- 7 Replies
- 599 Views
Last post by calif wingnut
