1200 Head Gasket Change
- Mike-C
Good Day Folks;
I am in the midst of changing the head gaskets on my 1200 Interstate and an slowly getting more and more paranoid. I took the left head off, removed the cam holder, changed the stem seals and lapped the valves. Now the problem, the front cylinder's (number 2?) valves are lightly open when I reinstalled the cam holder and as the piston is on TDC I am afraid I am going to bend something when I put the head back on. The cam is in the right place with the keyway straight up and is exactly where it was when I took it apart. Do the valves need to be bled? I do not remember the valves position when I took it apart. I have done valve jobs before but have never had a problem, as I said I am getting a bit paranoid . . .
I did my own 1200's LH head two weeks ago but it was a simple head gasket change, I did not remove the cam holder so nothing was disturbed.
Any advice would be appreciated.
Mike Coleman
'84 Wing-Lite (ex-Aspencade)
'84 (un-Terstate)
Mike Coleman
'84 (un-Terstate)
Mike Coleman
North Lancaster, Ontario
Canada
Canada
- RIP: cookie
Re: 1200 Head Gasket Change
Advice ?? Get it right ....
The lifters are hydraulic, and have to be bled before installed. And after installed keep the head upright before installing. They should self adjust..... but you probable knew that
- Mike-C
Gents;
I know the lifters are hydraulic, I will turn the cam a few revolutions and see if the valves lie down to where they should be. The head is still on the bench, I'll let y'all know what develops.
Mike Coleman
'84 (un-Terstate)
Mike Coleman
'84 (un-Terstate)
Mike Coleman
Canada
Canada
You’ll have zero compression for a while as they pump up. Keep cranking. I almost had a heart attack the first time I did it.
Do you have the manual?
- Mike-C
Hi Eric;
I have the manual and I have done the job before, I just never noticed that the 'TDC' cylinder's valves (#2 in this case) are slightly open and I am getting paranoid.
Mike Coleman
'84 (un-Terstate)
Mike Coleman
'84 (un-Terstate)
Mike Coleman
Canada
Canada
- Mike-C
Gents, Eric I agree.
I installed the head, etc and connected my compression gauge. Like you, I held my breath, gave everything a triple once over and connected the big car battery I have for reluctant engines, powered it right to the solenoid and held my breath. No compression ! UGH. I started to panic, and called myself all kinds of names. As an accomplished DIY mechanic on two, four, and six wheels, this cannot be happening! What did I do? By this time there was oil splashing everywhere (cam cover not installed) and I decided to install the cam cover and let it crank for a while. I installed the cam cover, reconnected the battery and after another 20 agonizing seconds I saw the needle on the gauge start to tickle, then it bounced around and then, gloriously, started to slowly rise 120, 140, 165 ! 165 LBS of wonderful compression. YEE HAH ! The end result was 165 lbs on number 2 and 160 LBS on number 4. I will re-install the spark plugs, the intake manifolds and loose fit the exhaust and then go ride on my Wing. I feel good and personally vindicated.
Tomorrow I will start on the RH side.
Mike Coleman
'84 (un-Terstate)
Mike Coleman
'84 (un-Terstate)
Mike Coleman
Canada
Canada
Been there, crapped that!
- Mike-C
Eric,
Yessir.
Mike Coleman
'84 (un-Terstate)
Yessir.
Mike Coleman
'84 (un-Terstate)
Mike Coleman
Canada
Canada
- RIP: cookie
Glad you took my advice ....
Gord(ever helpful)Jones
- Mike-C
Thanks Gord;
I could not have done it without you.
Mike Coleman
'84 (un-Terstate)
Mike Coleman
'84 (un-Terstate)
Mike Coleman
Canada
Canada
- 9 Replies
- 317 Views
Last post by desertrefugee
- 10 Replies
- 377 Views
Last post by Mike-C
- 8 Replies
- 662 Views
Last post by Pinball
- 18 Replies
- 847 Views
Last post by Track T 2411
