Fuel Gauge
Fuel Gauge
....sometimes it works, sometimes it doesn't...mostly doesn't.
Which end should I check as there a low voltage going into the sensor at the tank...not sure what that means tho?
All advice welcomed!
1982 GL1100 Standard
- BlueThunder
Re: Fuel Gauge
Make sure your float connections are clean and tight first. Then report back and we can go from there.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
Re: Fuel Gauge
If it helps there's no response at the dial when I remove the float etc from the tank and manually move it up and down slowly.
Re: Fuel Gauge
The fuel gauge uses 7 volts, and is wired through its own regulator. You can (very carefully) remove the metal cover and clean up the contacts where the float lever slides along the wire coil. Some people have had success with that. I say 'carefully' because there's a fine wire connection inside that you don't want to damage...
Re: Fuel Gauge
I see. I gather the regulator isn't separate from the unit and replaceable?
- 77Gowing
Re: Fuel Gauge
The 7v regulator is not part of the sending unit assembly. It is mounted underneath the LH panel.
Suggest you look at the shop manual.
"Less is More" Anonymous
77Gowing
1977 GL1000 "O'le Blue." (sold )
2014 Yamaha 950 V Star (sold)
77Gowing
Re: Fuel Gauge
Actually on the 1100's the 7v regulator is tucked under the instrument cluster...77Gowing wrote:The 7v regulator is not part of the sending unit assembly. It is mounted underneath the LH panel.
Re: Fuel Gauge
There ya go....see, always worth asking eh?Track T 2411 wrote: Actually on the 1100's the 7v regulator is tucked under the instrument cluster...
Thanks man....
Re: Fuel Gauge
Replacement 7 volt rgulators are available from the goldwingdocs site.
Re: Fuel Gauge
Cleaned sensor with no damage to small wire. No change. Temp gauge works, down the fuel gauge have its own regulator?
Re: Fuel Gauge
The temp gauge and fuel gauge use the same regulator, so if one or the other is working properly, it probably isn't the regulator.
- chewy999
Re: Fuel Gauge
Connect an ohmeter to the two contacts on the float assembly and then manually operate the float. The reading on the meter should go up and down. That at least checks that part. I soaked my float sender in white vinegar, after very carefully bending the small tabs on the cover to remove it. Worked very well.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
Re: Fuel Gauge
All fixed. Just rewired. Must have been a break in one of the wires.
- 11 Replies
- 499 Views
Last post by Chainman
- 1 Replies
- 139 Views
Last post by flyin900
- 7 Replies
- 552 Views
Last post by leggman
- 8 Replies
- 305 Views
Last post by blakewindham
- 2 Replies
- 222 Views
Last post by OldRider2
