How to use digital multi meter for rpms
80corvette
Rusty Probie
Rusty Probie
Post by 80corvette »
Where do you connect the multi meter to measure rpms
desertrefugee
Re: How to use digital multi meter for rpms
Post by desertrefugee »
Cant get there with a DMM. An oscilloscope is needed. You need to measure pulses.
heraldhamster
Post by heraldhamster »
hmm, really?
I never knew this.
Thanks!
H2G2=42
flyin900
Post by flyin900 »
Don’t believe that is correct as my DMM has a section for RPM on a variety of multi cylinder engines. Don’t ask me how to use it though, as I have never hooked it up for that purpose and don’t have the instruction anymore.
Current Bikes:
pidjones
Post by pidjones »
So, not just any DMM, but rather one that has the tach function.
Shadowjack
Post by Shadowjack »
A very specialized tool, that. I've never seen one, and I used to use electronic test equipment professionally.
Several of the Fluke DMM's have a RMS function that can be used for this.
desertrefugee
RMS function won’t get you there. As noted, you’ll need the specialized instruments which can be expensive have to be configured to measure ignition pulses going to the coil. RMS simply gives you another way of looking at AC power other than peak to peak.
Since those aren’t typical DMMs, I did not consider them in the discussion.
All you do is take the rms and multiply by 60. Then correct it for the wasted spark.
flyin900
Post by flyin900 »
Here's the one I have, yet only use it for electrical/impedance stuff. Should try to find the instructions and see how this other stuff works.
Current Bikes:
desertrefugee
Whiskerfish wrote:All you do is take the rms and multiply by 60. Then correct it for the wasted spark.
Hmm. That works? I'll be danged. I guess its using the RMS function to measure the pulse frequency and then mutiply to get one minute. If youre only looking at one coil, maybe the wasted spark correction isnt needed?
mikenixon
Early 'Wing Guru
Early 'Wing Guru
Post by mikenixon »
As I recall, Fluke sells an rpm attachment for their digital multimeters. Never tried it though. Most shops use standalone rpm test tools. Used a lot on ATVs and other vehicles to set idle speed carefully so as to be compatible with CVT (automatic transmission) systems.
Shadowjack
In electronics RMS stands for Root Mean Square and is the DC equivalent of an AC wave. Nothing to do with frequency.
desertrefugee
This got my interest up. Poked around a bit. You can calculate frequency using a true RMS meter. Since most alternating current sources are not a clean, pure sine wave, straight RMS calculations will not work. Or at least would not be very accurate. That’s why true RMS methods are used. Also, the sample window must be short and defined or the frame needs to be short enough so that voltage changes cannot corrupt the calculation - a constant, stable peak to peak amplitude is essential.
I suspect that the generic DMM versions of "tachs" are adequate, but not entirely accurate. I could be wrong, but if you're looking for precision, a dedicated instrument would be the route to take.
I spent some time (decades) in an engineering lab, but mostly slinging code.
DUGG
Post by DUGG »
My fluke 78 has functions for rpm and dwell but it was built for the auto repair industry. To use the rpm it has an inductive clamp that goes around a plug wire. Some timing light have rpm functions as well.
To use a Dmm it would have to be able to have graphing features so you could see the waveform. Seems in this day and age there must be a cheap inductive tach out there.
