With interest, I will explain a good way to open GL gauges
- JohnBaxter
Re: With interest, I will explain a good way to open GL gauges
Count me in the list, I'd be extremely interested in how it's done, and if it can be done without looking like a train wreck.
When the Power of Love
Overcomes the Love of Power,
Then and ONLY then
Will we find peace.
Then and ONLY then
Will we find peace.
- ianstaley
I didn't clean them up, on mine they were beyond repair. New ones don't exist any more, so I looked around and as I had white faces I went for some VDO gauges, they are in white and look old fashioned, I think they are called Cockpit Royale. The faces are whit and the they are 12 volt so the 7 volt thing is only used for the main clocks.
You can view and get the clocks here ---> http://www.vdo-gauges.com/instruments-d ... oyale.html
- warhead_71
- My Album: https://www.ngwclub.com/gallery3/index. ... _71?page=2
For the trip boot, I wonder if a wheel valve stem would work. You'd have to remove the valve core, or pull the rubber from the brass tube. But the diameter looks about right, and you can get a free or cheap used one at any tire store.
Mine is dry rotted, so I might give it a go.
Interesting idea. I think just about everyone I have ever seen has dry rot issues.
- Sandy
That's what I did on the one of the rebuilds.warhead_71 wrote:For the trip boot, I wonder if a wheel valve stem would work. You'd have to remove the valve core, or pull the rubber from the brass tube. But the diameter looks about right, and you can get a free or cheap used one at any tire store.
The tire stem fits but does not have the slight offset of the original making bind a bit on the shaft.
Still acceptable.
Sandy
1971 Honda CB350
1974 Honda XL350
1975 Red GL1000 (gone from stable but still in the family)
1976 (original owner in 76) Sulpher Yellow GL1000
1977 Restored then Triked Sulpher Yellow GL1000
1976 (garage find completed 2015) Sulpher Yellow GL1000
1978 Watsonian Monaco
1960 IH B414
http://www.flickr.com/photos/76_gl1000_project
Sandy
1971 Honda CB350
1974 Honda XL350
1960 IH B414
- warhead_71
My other option is to simply put some heat shrink over the existing rotted boot. The dry rot will still be there, but it will look prettier. I could even do a couple layers to beef it up a bit.
- Sandy
Did that on the first one I repaired.warhead_71 wrote:My other option is to simply put some heat shrink over the existing rotted boot. The dry rot will still be there, but it will look prettier. I could even do a couple layers to beef it up a bit.
Worked well and still in operation.
- Johnnygoesnaked
Right. Thanks for the links and thoughts guys. Some playing aroudn to do this weekend but I think this one's toast eitherway. Might as well try Pete's method and see if I can get anything working
GL1100 interstate 81, stock black, naked with panniers
- BikeMaine
- tlbranth
Been messing with gauges using Pete's method. I'm terrible at removing the ring but I must say the #12 copper wire caper is brilliant. I think I found a better way to reassemble though. I got this from a Youtube video. The wood jig takes the clamping strain off the lens piece. The ring is tapped down using a hardwood dowel, tapping done in increments. The part of the ring that you see when the gauge is on the bike remains unmolested.
I made this jig from 3/4" plywood and glued on 3/4" plywood feet. If you're inclined to make one, I would add a 5th foot under the saw kerf. The thing flexes there. I glued on a strip of hardwood but a foot would be better.
I'd like to say my project was successful but I managed to bugger it up in so many other ways.......
The ring jig is good though and I think it's an improvement over Pete's original reassembly method.
Sorry one of the pics is rotated. Even though 35 years a programmer, I purposely forgot all tech mumbo-jumbo when I escaped Boeing.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1975 GL1000
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1975 GL1000
1970 CB750
I rescued a '79 CB750F last winter that had been outdoors since at least 1999. Both the speedo and tach needed opening, lubrication of the needle pivot (I use silicone spray lube - very thin and lasts a long time). But, before opening the speedo I took the bike for its first test ride and returned with the speedo needle shattered (I swear I didn't ride that fast)! This was to be a rat bike that performed well but looks did not mater, so I replaced the broken needle with a strip cut from a 90 degree angle along a piece of clam shell packaging. I put some fluorescent orange paint on the inside of the angle, then glued it to the remaining center of the original needle. Worked great!
tagging this..
I thought I would add another "you tube" video to your link. I found this video and it show a lot of the same suggestions as Pete did in his tutorial in this conversation.
https://www.youtube.com/watch?v=PLU2sCFx6qU
Dave D.
84 1200 GW Std
02 1800 GW
84 1200 GW Std
02 1800 GW
- Rusty Probie
I am trying to follow this great idea, but I’m struggling to get the rubber off the brass core. Can someone enlighten me please?BikeMaine wrote:I'm posting just to refresh this thread as it is very good information.
As for a boot around the trip knob, as someone else mentioned, a tire valve-stem with the metal removed works well.
Thanks
- 140 Replies
- 11932 Views
Last post by Lowrider Bud
- 13 Replies
- 980 Views
Last post by gltriker
