Fuel pump bypass
Tom61
Lead Member
Lead Member
Fuel pump bypass
Post by Tom61 »
download/file.php?mode=view&id=77359
Cheap easy mod to prime the carbs after drain down or when your wing has been stood for a while. Just open the fuel cock open the valve wait a minute close the bypass valve then start her up. Ideal for early wings with mechanical fuel pumps.
Saves all that cranking.
Re: Fuel pump bypass
anim-cheers1 anim-cheers1 Saves the starter
I like it. Thank you for posting. Will you be selling the kit? LOL.
05c50
Post by 05c50 »
If I remember correctly, Pistol Pete posted something like that a few years ago and he was selling them. I'm old so don't quote me on that.
......Paul
I prefer to ride my wing naked,thank you
My wife asked me "How many bikes does one man need?" My answer "Uhhh.just one more"
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
05c50
Post by 05c50 »
Maybe it was Randall.
......Paul
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
I use an electric fuel pump..... does the same thing Less moving parts action1
CYBORG wrote:I use an electric fuel pump..... does the same thing Less moving parts action1
And you don't have to remember to move a lever one way then the other. ;)
Cakey
Post by Cakey »
Great idea. Any pics of one set up on the bike? It’s one thing that annoys me as I religiously run the bowls dry now after getting sick of pulling the carbs off and cleaning when it sat to long and I had not run it dry.
1975 Gl1000
One thing to remember. The tank would need to be at least 1/2 full for this to work.
Cakey
Post by Cakey »
Good advice as always Robin.
1975 Gl1000
Tom61
Lead Member
Lead Member
Post by Tom61 »
robin1731 wrote:One thing to remember. The tank would need to be at least 1/2 full for this to work.
I find as long as the gas cap hasn't been moved there is enough natural pressure in the tank to push the fuel through even when its quite low.
Perhaps when outside temp is high. But in cooler weather the pressure will go down and won't be as successful at feeding the carbs which are then above the fuel level.
Explorer
Post by Explorer »
I was thinking along those lines too, isn't the whole idea of the pump because in general there is no height, gravitational pressure difference, between the gas tank and the float bowl(s)?
desertrefugee
Post by desertrefugee »
Man, do I like this idea. However, like cyborg, my 1000 also employs an electric fuel pump but the vast majority of them don’t. This is a great idea.
Explorer
Post by Explorer »
desertrefugee wrote:Man, do I like this idea. However, like cyborg, my 1000 also employs an electric fuel pump but the vast majority of them don’t. This is a great idea.
i gotta admit, I'm not as totally convinced as you are.
So you've either got to put the bike up with a full tank of gas for long enough for the bowl(s) to go dry. Or go down the road, get gas and fill it up, just to save a few seconds of starter motor use? Hmmmm!
