My 77 GL full custom build
- Brass Member
So I bought this 77 back in 2013 as a runner with the intention to do a full build. It sat a while but around Nov of last year I got on it and getting close to finishing it up. I have many build pics of the process so I will post them in this thread. First pics are beginning and ending
- MyGL_03[1].jpg (252.63 KiB) Viewed 4162 times
- 20210814_205228~01[1].jpg (228.94 KiB) Viewed 4162 times
- 20210814_205259~01[1].jpg (222.16 KiB) Viewed 4162 times
1977 GL1000
Full Custom!!!
Full Custom!!!
- Brass Member
Re: My 77 GL full custom build
Right away I knew I wanted to mono shock it and do an USD upgrade. Also I wanted to hide as best as I could the cooling system. So I started cutting chopping and welding!
- MyGL_09[1].jpg (220.41 KiB) Viewed 4160 times
- IMG_20140213_172810[1].jpg (204.45 KiB) Viewed 4160 times
- 20210222_170801~01[1].jpg (199.08 KiB) Viewed 4160 times
1977 GL1000
Full Custom!!!
Full Custom!!!
- Brass Member
The forks are from a ZX10R Kawie, I machined off the stock stem from the triple and machined the ZX10 to press fit it into that triple so I used the factory bearings in the stem. It worked out great. As for the rear I used a shock from a Suzuk Katana because it was the correct measurement. All pipe work was fabbed up and welded by me.
- photo0(4)[1].jpeg (115.89 KiB) Viewed 4158 times
- 20210319_171856[1].jpg (196.68 KiB) Viewed 4158 times
- 20210321_184753[1].jpg (192.13 KiB) Viewed 4158 times
1977 GL1000
Full Custom!!!
Full Custom!!!
- Brass Member
Once I had the basic design that I liked I started on the tail section. The radiator I used is from a Suz TL1000. Dual 7" fans fit it perfectly and are switched by the Suz temp switch mounted in the radiator. So using the rad I fabbed up how I wanted the rear to sit with tubing and just made it all fit!
- 20210323_175808[1].jpg (176.72 KiB) Viewed 4156 times
- 20210323_181342[1].jpg (222.88 KiB) Viewed 4156 times
- 20210403_132903[1].jpg (196.11 KiB) Viewed 4156 times
1977 GL1000
Full Custom!!!
Full Custom!!!
- Brass Member
So the seat was a flebay special, the measurements were what I needed so using the seat I made a tail from steel and glass. I do have some leather I plan to recover the seat and change the pleating and thread design. So this isn't the final look on the seat but it is for the tail piece.
- 20210403_132917[1].jpg (190.62 KiB) Viewed 4154 times
- 20210417_114252[1].jpg (208.81 KiB) Viewed 4154 times
- 20210417_184531[1].jpg (117.99 KiB) Viewed 4154 times
1977 GL1000
Full Custom!!!
Full Custom!!!
- Brass Member
Once that was done I finished up the swing arm bridging and put everything in some good 2 part urethane primer.
- 20210331_173124[1].jpg (207.39 KiB) Viewed 4152 times
- 20210421_204845[1].jpg (192.05 KiB) Viewed 4152 times
- 20210421_204900[1].jpg (186.45 KiB) Viewed 4152 times
1977 GL1000
Full Custom!!!
Full Custom!!!
- Brass Member
So I went rounds and rounds on color choice. I am not a fan of white, in fact it's my least fav color.. And pretty much everything I build is black or some combination with black. But for this build I went against my feeling and chose blue frame and pearl white bodywork. Then as for drivetrain I knew I wanted wrinkle finish flat black. So I media blasted everything and sprayed it. Turned out really nice!
- 20210510_194514~01[1].jpg (101.04 KiB) Viewed 4150 times
- 20210502_164804[1].jpg (198.88 KiB) Viewed 4150 times
- 20210513_183436[1].jpg (203.2 KiB) Viewed 4150 times
1977 GL1000
Full Custom!!!
Full Custom!!!
- Brass Member
I blasted the wheels and sprayed them. Black spokes and blue rings with a white stripe, new shoes. The front fender is a glass fender I built a few years back for another bike project, it got removed and so I reused it on this build.
- 20210501_205725[1].jpg (188.26 KiB) Viewed 4147 times
- 20210504_182402[1].jpg (140.43 KiB) Viewed 4147 times
- 20210504_191108[1].jpg (169.84 KiB) Viewed 4147 times
1977 GL1000
Full Custom!!!
Full Custom!!!
- Brass Member
Once the bodywork was sprayed and dry I mocked it up, by this point I still had a long way to go but I was getting excited!!
- 20210514_132833[1].jpg (199.22 KiB) Viewed 4143 times
- 20210514_133259[1].jpg (218.87 KiB) Viewed 4143 times
- 20210522_162834~01[1].jpg (133.61 KiB) Viewed 4143 times
1977 GL1000
Full Custom!!!
Full Custom!!!
- Brass Member
A few things I will cover, the rear brake master is a ebay special I fabbed up mounts for. The front calipers fit the factory rotors I just had to trim the mount pedestals. The controls are original Goldwing, I blasted and resprayed them. The bars are some low sport bars I got off the net. I just drilled the upper triple and threw some risers on it. I rebuilt the rear caliper and the front master. Custom length lines finished off the brakes.
1977 GL1000
Full Custom!!!
Full Custom!!!
- ritalz
That's quite a transformation. Very sporty. Nice job.
- Brass Member
Once all this was done I started on my dash, controls and wiring. The headlight bucket is from a HD, I built a bracket that bolts to the head so nothing moves with the steering. I have 3 gauges, a GPS speedo, a temp gauge and a small tach that will run off the coil. The dash fabbed up from sheet metal and 3/16 rod. The wind screen is a internet special, I trimmed it to look better and painted it to match the bodywork.
- 20210519_163859[1].jpg (196.35 KiB) Viewed 4136 times
- 20210624_184333[1].jpg (199.64 KiB) Viewed 4136 times
- 20210618_194134[1].jpg (162.33 KiB) Viewed 4136 times
- 20210626_135247[1].jpg (181.3 KiB) Viewed 4136 times
1977 GL1000
Full Custom!!!
Full Custom!!!
- Brass Member
So with the carbs I went with 40IDFs cable operated by a 69 CB350 splitter cable. I made the manifolds and brackets. The air filters are individual paper puck filters that slide down inside the horns off of an air pump.
- 20210721_194620[1].jpg (212.39 KiB) Viewed 4133 times
- 20210812_175259[1].jpg (204.23 KiB) Viewed 4133 times
1977 GL1000
Full Custom!!!
Full Custom!!!
- Brass Member
The battery is a small Lith Ion with 330CCA. Dyna CDI conversion and coils. The regulator is for a Lith batt. I built a battery box and then attached everything to it and it is all hidden under the tank. All wiring done by me, I ran the circuits I wanted and left out the rest!
- 20210721_195642[1].jpg (177.85 KiB) Viewed 4132 times
1977 GL1000
Full Custom!!!
Full Custom!!!
- Brass Member
On the exhaust I wanted something small and hidden to really show off the frame. So I built a collector muffler using the stock head pipes and thermo wrapped them. One of my last issues was running the coolant lines. The supply runs under the bike, I fabbed up several steel pipe bends and such. The return (off the heads) runs through a T and into a steel line back to the rad.
- 20210801_162003[1].jpg (161.13 KiB) Viewed 4130 times
- 20210731_121641[1].jpg (230.46 KiB) Viewed 4130 times
- 20210802_191504[1].jpg (246.92 KiB) Viewed 4130 times
1977 GL1000
Full Custom!!!
Full Custom!!!
