75 GL not running on number 2 cylinder
I have spark and fuel in bowl but no fuel getting to cylinder. I just rebuilt the carbs with Randakk's kit, ran the carbs threw the sonic cleaner two times. I put them back together and it starts and will even idle ok. I just can't think of what I might have done or not done to cause this. Any ideas on what this might be would be great.
79 GL1000,75 GL1000,76 GL1000 LTD,70 CB750k JDM, 79 CBX, 2000 Valkyrie CT 2008 Goldwing Roadsmith
Trike and another 76 LTD bad shape, and several more for parts.
- tlbranth
Re: 75 GL not running on number 2 cylinder
#2 exhaust not getting warm at idle? at higher rpm?
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1975 GL1000
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1975 GL1000
1970 CB750
Compression test good, # 2 not getting hot like the others. New plug no gas on plug even after running it till it gets hot enough for fan to come on.
- tlbranth
If you have spark and fuel in the bowl, I'd look for a stuck slide. Not sure why you still wouldn't get something through the idle circuit though.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1975 GL1000
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1975 GL1000
1970 CB750
If the cylinder starts to fire and the header gets hot at higher RPMs, I would look at the idle/slow jet and its associated idle circuit.
1983 GL1100A Aspencade
1977 GL1000
1978 GL1000
1979 GL1000
“I see Angels on Ariels in leather and chrome,
Swoopin' down from Heaven to carry me home."
1977 GL1000
1978 GL1000
1979 GL1000
Thanks guys, that cylinder is not getting hot as it should only around 150 while others are above 300. It dose this no matter what RPM from idle to 3000 or more. I guess I was hoping for something so I would have to take the carbs off but looks like that is what is going to have to happen.
Cliff (74yrs )
- tlbranth
Well it could indeed be a stuck slide then. No need to pull the carbs. Just remove the 8 bolts holding the manifolds to the heads and slide the carb assembly to the left enough to get #2 cap off. Watch out for the manifold o-rings.6adan wrote: ↑Tue Sep 14, 2021 1:47 pm Thanks guys, that cylinder is not getting hot as it should only around 150 while others are above 300. It dose this no matter what RPM from idle to 3000 or more. I guess I was hoping for something so I would have to take the carbs off but looks like that is what is going to have to happen.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1975 GL1000
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1975 GL1000
1970 CB750
I believe Randakk’s kits do not come with the float valves. Did you pull the seats out anyway and clean the screens that’s attached to them?
1975 GL1000 Restored (sold)
1983 GL1100 Custom (sold)
hoo boy
Cliff (74yrs )
Thank you everyone for all the advise. Just wanted to let you know what I found (it was all my fault). I wound up taking the carbs off and recleaned the carb again and when I started to put it back together I somehow had put two float bowl gaskets on #1 and none on #2 so now I have it back together it is now running fine.
Thanks for the follow-up!
I have never bought a GL1000 or 1100 that were running. Some were closer than others but no runners.
- ritalz
Ne neither. I have sold a few that were running when they left here.
- 3 Replies
- 195 Views
Last post by timma11
- 17 Replies
- 1079 Views
Last post by heraldhamster
- 2 Replies
- 195 Views
Last post by robin1731
- 2 Replies
- 483 Views
Last post by sideshowbob
- 7 Replies
- 651 Views
Last post by MattMcCoy
