Stuck idler bolt
Stuck idler bolt
I’m changing the belts on the 76 and one of the bolts that holds the idler on is seized in the block. It turned about a 1/4 of a turn then got tighter. I fee that if I keep going it’s going to break. Any suggestions on how to free it up?
1975 GL1000 Restored (sold)
1983 GL1100 Custom (sold)
Re: Stuck idler bolt
Spray some PB Blaster on it, let it sit for a while to work its way in and then work the bolt back & forth within that 1/4 turn to work the penetrant between the threads farther until it moves more.
- salukispeed
Lots of patience and PB and back and forth. some like other rust busty stuff but PB is usually a reasonable choice. If you have not tried anything yet I and some like Kroil even better but time and patience, Once you force it in frustration it is broken and then you are in a real pickle.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
thanks guys That did the trick. Got it out without pulling any threads. Cleaned up the corroded bolt and ran a tap in the hole and it runs in freely now.
If the bolt's threads were rusty that means that the sacrificial zinc coating is used up and it is time to replace the bolt so it doesn't happen again.
- flyin900
It is also a best practice to use an anti seize on any bolts while you have them out, as the galvanic corrosion between the aluminum and steel/zinc plating on the threads, which is usually long gone now. I find many bolts and JIS screws threads are covered with a white gunk along with rust from 40+ years of age.
Current Bikes:
I use anti seize on all steel bolts that screw into aluminum.
That's nice but it won't protect like a layer of zinc.
I use the spray on zinc, and anti seize.
As long as it is something like this and not a zinc bearing primer
https://www.3mcanada.ca/3M/en_CA/p/d/v000159473/
