Click-clack-clunky noise from rear end while rolling.
Moderators: robin1731, Oldewing, CYBORG, Forum Moderators
1983lux
Post by 1983lux »
Hi all,
I have some weird noises coming from the back end of my GL1000 when rolling. It is most noticeable when rolling the bike with engine shut off. Here's a couple of videos. One is with the bike in gear after pulling into my driveway, i hit the killswitch and then you can clearly hear the noise.
https://www.youtube.com/shorts/4mdY55Wr1gI
Also another video of just rolling the bike backward in neutral
https://www.youtube.com/shorts/EiphtYB6R9M
When I put the bike up on the centerstand in neutral and turn the wheel, i get a bit of brake rub but no noises like that. Also, if I push the tire side to side there doesn't seem to be any clicking or wiggle.
Any thoughts on this? Thanks
1975 Honda GL1000 - Naked
Motor from 1979 Model
1975 Cams and Carbs
Dyna S Ignition
Sagebrush
Re: Click-clack-clunky noise from rear end while rolling.
Post by Sagebrush »
Check the drive shaft under the boot could also be the splines at the rear of the drive shaft.
1983lux
Post by 1983lux »
Here's some pics (best I could do) with the boot pulled back. Anything look amiss?
1975 Cams and Carbs
Dyna S Ignition
1983lux
Post by 1983lux »
I had the hub off the back last time I changed my rear tire (last year i think). At that time, I checked and used Honday moly M77 grease on the splines from the hub to the wheel, and the hub to the back of the driveshaft. None of them looked worn or tired to my eye at least.
Here's another video of me messing with the rear wheel while its on the stand:
https://www.youtube.com/shorts/qBK4gduEtWk
Strangely, as I went to put the bike away, I can't reproduce the noise at all!! Whether rolling in gear or in neutral, bike on or off, I don't hear any clicks at all. Only difference would be that the bike is now cold. Is there a bearing in the final drive or something that'd only make noise when it's hot? Strange.
1975 Cams and Carbs
Dyna S Ignition
Sagebrush
Post by Sagebrush »
You might drain the rear drive oil and inspect for metalic particles.
Cliff (74yrs ;) )
pidjones
Post by pidjones »
While the U-joint boot is pulled back, grap it with some lkng-nose pliers and give it a good shake.
1983lux
Post by 1983lux »
Will check fluid and use the vice grips next time I’m in the shop, but suspecting bad swingarm bearings like this post could be a possibility:
https://goldwingdocs.com/forum/viewtopi ... =4&t=66496
allowing the swingarm to move side to side slightly and the driveshaft to rub against the inside tube might explain the issue? (Especially how it’s intermittent). A sharp turn one way could cause it to rub, then turning the other way could slide it a few MM back to the correct position 🧐
Any tips on how to rule out the swingarm? I’ve never touched those bearings in the 10 years I’ve had the bike, could be original for all I know
1975 Cams and Carbs
Dyna S Ignition
1983lux
Post by 1983lux »
So, finally got to taking the whole back end of the bike apart. Swingarm bearings and thrust bushes looked ok, but replaced bearings anyway. Driveshaft u-joint like new. Wheel bearings seem fine although the spacer inside the wheel seems noisy when I move it around. Splines where driveshaft meets final drive were pretty dry, some visible wear. The m77 I put on a couple years ago mostly flew off. Maybe that was the source. I’ll regrease the hell out of everything, replace wheel bearings, rebuild rear caliper, then see how it goes when all reassembled.
1975 Cams and Carbs
Dyna S Ignition
1983lux
Post by 1983lux »
Mystery solved, bad wheel bearing. For some reason, was hard to detect as the outside looked fine, it didn’t make noises off the bike, and didn’t feel rough when spinning with my finger. Once I popped it out of the wheel though, it was obviously bad.
Probably didn’t hurt to do the swingarm bearings anyway though, and the final drive certainly was in dire need of grease, feel less of a clunk on takeoff now.
1975 Cams and Carbs
Dyna S Ignition
Sagebrush
Post by Sagebrush »
Always good to find the cause of an unusual noise. Good thing you pursued it.
kerryb
Post by kerryb »
Good catch!
