Fused wire mess
tory
Fused wire mess
Post by tory »
I DIDNT DO IT!!
Works, but not sure why, and looks thin and schetchy.
I want to redo this and clean it up. Im not sure exactly why this is wired like it is. I'm confused why the fused wire to battery also bypasses the fuse and goes direct to battery?
Any advice on best way to correct this?
1978 GL1000
1986 GL1200 Aspencade
With California Sidecar
1965 CA95 Benly
Re: Fused wire mess
not sure it does.
the two wires in the white connector may not go to the same battery post. I wuld trace them out
Re: Fused wire mess
Check out the wiring diagram link posted at the bottom of the ShopTalk page. You'll find what that group of wires is supposed to look like. There's a few pics from my '76, before and after in this thread... viewtopic.php?t=67088
I don't have a pic of the final hookup of the two loose ends, unfortunately...
LuckyEddie
Re: Fused wire mess
Post by LuckyEddie »
That is a fix to bypass the dogbone fuse that is only available from Honda. Now a fuse is available most anywhere. It is a common work around.
LuckyEddie
1978 GL1000 Supercharged (Avitar)
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
Rednaxs60
Re: Fused wire mess
Post by Rednaxs60 »
Best way to fix this wiring issue is to install a new starter solenoid with the blade fuse, inexpensive off shore solenoid will work just fine, and connect the wires to it. If there are wires left over - may happen, find what theses wires are for. Here are two pics:
starter solenoid.JPG (217.3 KiB) Viewed 126 times
Starter Solenoid Wiring.jpg (168.12 KiB) Viewed 126 times
Good luck
2021 Royal Enfield Himalayan
redglbx
Re: Fused wire mess
Post by redglbx »
Ernest , great job !
Anyone have a good source for a board/connector to wire a full 12v to and then distribute to things like the headlight, coils, etc ? I currently have those just attached to the positive post & solenoid which is a terrible way to do things and would like to do a cleaner setup. I know I’ve seen several setups here by somebody but doing a search gave me nothing.
Re: Fused wire mess
Very nice action1 action1 action1 action1 action1
Re: Fused wire mess
The solenoids with the blade fuse are functionally the same as the ones with the open link (dogbone) fuse under a cover on the side as supplied with the GL1100, GL500, GL650 and probably most new Honda models from about 1980 until they changed to blade fuses.
There should be an internal connection between where the red wire and the red/white wire connect and the fuse is connected between that and the B terminal
Note also that those solenoids come in 2 versions, as shown and with the B and M terminals reversed (I don't think 4 pole wiring connector is reversed).
