https://ngwclub.com/forum/viewtopic.php ... 81#p828672
Why drain the carbs????!!!!!!!!
I'll let the pics explain. Before and after. If you send carbs that look like this expect to pay a little bit more.
Re: Why drain the carbs????!!!!!!!!
Varnish is for wood not Carbs!
- dontwantapickle
Did you vapor blast those carb parts?
looks great.
looks great.
No. Have to completely disassemble to vapor blast. Throttle shafts and all. I soda blasted these. After a long very hot soak in the ultrasonic tank to get most of the varnish off. Spent nearly an hour then cleaning the tank.
Does running wing til it dies get bowls dry enough? Thanks Robin.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
Running my '75 engine until it dies leaves quite a bit in the bowls still. I always drain them into a flattened-out pan after running until it dies.
No. After that put a rag under the bowls and open the drain screws till fuel stops coming out. You'll be surprised how much is still in each bowl.
I use a rag too, and when I'm done I sit it in a place where the fire can't spread, ignite it, hang around until there are no flames and then douse the ashes.
BTW, the potential for deposits like that is why I prefer to drain the tank too.
Your right, Mucho fuel left in carb bowls after closing petcock and running til it dies.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
- My Album: https://www.ngwclub.com/forum/viewtopic ... it=GW+Hobo
Does using marine fuel (non-ethanol) alleviate the need to drain the bowls when not used for extended periods? I usually don't go more than two months without riding but I never want to clean my carbs again either. That was painful. Thanks in advance for the feedback.
1982 GL1100 Cafe - Born Naked
2020 October BOM
2020 October BOM
No. Any gasoline will evaporate and turn to "varnish" over time.
- 6 Replies
- 447 Views
Last post by enrique dauner
- 12 Replies
- 862 Views
Last post by Sidecar Bob
- 15 Replies
- 1902 Views
Last post by Earl43P
- 8 Replies
- 579 Views
Last post by BikeMaine
