resurrecting a 81 standard
nakedall
Re: resurrecting a 81 standard
Post by nakedall »
Today I worked on the rear master and front master, I had to put the grease fitting on the rear master and a piece of rubber and a c- clamp over the reservior hole to block it,the internals came out with a little work. I cleaned the the inside of the cylinder with red scotch brite pad folded and taped to a drill bit.
pat
84 standard black
81-83 standard
79 complete needs work
78 a mess now parts bike
nakedall
Post by nakedall »
Today After the day out with the wife I pulled out the buffer and cleaned up 1 intake manifold runner, came out nice. 3 more to go and then the timing covers and valve covers.
pat
84 standard black
81-83 standard
nakedall
Post by nakedall »
Today I finished up painting the frame and the final drive,Took off the swing arm and the clip was gone on the driveshaft?So I need to get one,size anyone?also buffed half of the timing cover. boy what a difference!carbs are waiting.
pat
84 standard black
81-83 standard
gregforesi
Post by gregforesi »
94510-20000 CIRCLIP (OUTER) (20MM)
It looks like it's still available from Honda. The one that holds the coupler (at the final drive end) is the same part.
BTW nice buffer.
2006 GL1800 (Brutus Maximus)
nakedall
#20
Post by nakedall »
Thanks for the info on the clip, The buffer was $89.00 about 10 years ago I buffed a lot of Triumph parts with it.
pat
84 standard black
81-83 standard
nakedall
#21
Post by nakedall »
painted parts pics
pat
84 standard black
81-83 standard
nakedall
#22
Post by nakedall »
wheels,front taped,up. rear painted
pat
84 standard black
81-83 standard
nakedall
#23
Post by nakedall »
Buffed the edges of the wheels today with air powered buffer, red rouge and then white they came out acceptable. I may do them again or sand them first. they look fine from 2 feet lolol
pat
84 standard black
81-83 standard
nakedall
#24
Post by nakedall »
Got the 83 swingarm today with a driveshaft for $38.00 shipped,So some cleaning and painting next.
pat
84 standard black
81-83 standard
nakedall
#25
Post by nakedall »
Did a little swingarm painting today, it rained now I will be doing it again,the paint turned flat?
pat
84 standard black
81-83 standard
#26
nakedall wrote:Did a little swingarm painting today, it rained now I will be doing it again,the paint turned flat?
Yeah, I've seen black turn almost white when the humidity was too high.
nakedall
#27
Post by nakedall »
Yea it turned a medium gray!
pat
84 standard black
81-83 standard
#28
How is the fitment of that 83 rear end going?
nakedall
#29
Post by nakedall »
Repainted the swingarm today so a little delay.
pat
84 standard black
81-83 standard
nakedall
#30
Post by nakedall »
Ran into a little cash flow problem so it slowed the work alittle, but I ordered the tires today. I am trying the shinko tourmaster 230 120/90 18 front and 140/90 16 rear $130.00 shipped motorcycle superstore I read they are pretty good so for the price can't lose.
pat
84 standard black
81-83 standard
