MAKING A TRIKE
Easter
Re: MAKING A TRIKE
#541
Post by Easter »
If you are using the Dyna coils, you will not need to use it. Check that instruction sheet to be sure but I don't think so.
83 GL in process :IDTS:
transitman
Re: MAKING A TRIKE
#542
Post by transitman »
Thank you both, and another one bites the dust
"Say not the struggle naught availeth." A H Clough.
'78 GL1000 Trike
1st bike: '58 150cc Ambassador 2 stroke. learned how to chuck it down the road
'31 BSA 500 single long stroke Sloper, dug out of a wall in Sussex, never went that well...
'49 Sunbeam S8, built from bits in '67, used daily, sold to a US biker in '84, still miss it
3 BSA Bantams, now a daughter has one
'78 Honda 500T
transitman
Re: MAKING A TRIKE
#543
Left hand rear lights fitted, poor photo, taken into light.
Lights are LEDs so will have to take care to do the earth first
This is the cabling for the rear lights, they come out under my seat.
And this is the other end, with the cables from the light unit coming in from a length of 15mm copper tube. Couldn't get them through the tubing.
This is the mobility trike hoist that will carry a small electric trike hanging on the back. Held on with 4 bolts.
Last pic, one of the two panniers, I think you call them sidebags, will be mounted here, held on with 2 metal straps.
That's about it for now, just had to go out and buy a bag of bolts and next week will take the second back wheel to be built up. May also get the cables made too, then I can finish the carbs.
'78 GL1000 Trike
'78 Honda 500T
wingrider
Re: MAKING A TRIKE
#544
Post by wingrider »
Coming Along nicely! Keep up the good work!
transitman
Re: MAKING A TRIKE
#545
Thank you!
'78 GL1000 Trike
'78 Honda 500T
Old Fogey
Re: MAKING A TRIKE
#546
Post by Old Fogey »
Doing well, my friend! Neat idea on the hoist; I'm impressed.
Re: MAKING A TRIKE
#547
So it's a six wheeler?
Re: MAKING A TRIKE
#548
Nice to have a 'spare' ....good work ....
'13 Honda NC700sa … TNG
transitman
Re: MAKING A TRIKE
#549
Details, details
First pic shows detail of jockey shifter. 2 stepped bushes either side of the lever so the nut can be tight but leave the lever free
Next pic shows the gearbox selector end of the jockey shifter and the last pic shows it in side view.
At the moment the exhausts are loose and the shifter needs adjusting back as it is fouling both the pipe and the frame, but there is plenty of adjustment available.
The clutch is on top of the lever and shifts are quite a short throw with leverage I've given it.
This fairly useless pic shows the lever tightened up. Even if it is sideways. Shows it fits ok anyway
You can also see my home made exhaust nuts, nice and long for easy access and brass makes them non stick.
Doing quite a lot at the moment, weather warm, daylight long, couldn't be better really.
'78 GL1000 Trike
'78 Honda 500T
transitman
Re: MAKING A TRIKE
#550
Missed your post Eric, yes indeed a 6 wheeler!
'78 GL1000 Trike
'78 Honda 500T
duke182
My Album: http://ngwclub.com/gallery/v/wingmans/duke182/
Re: MAKING A TRIKE
#551
Post by duke182 »
Every tome I check in im met with great inovation.
Im convinced this is going tobe outstanding when finished.
Keep up the awesome work!
1984 1200 standard
click pic to see my gallery
vote in my poll
Easter
Re: MAKING A TRIKE
#552
Post by Easter »
To make a bad pun (in reference to your photo) you can see the daylight at the end of the tunnel now. Looking great.
Re: MAKING A TRIKE
#553
Those brass exhaust studs could be a big seller ....
Gord action1
Shadow Dreamer
Re: MAKING A TRIKE
#554
Post by Shadow Dreamer »
looking good
~SD
Last edited by Shadow Dreamer on Sat Jun 18, 2016 11:21 pm, edited 1 time in total.
Easter
Re: MAKING A TRIKE
#555
Post by Easter »
Shadow Dreamer,
Start a thread (after going through the preliminaries) and keep us up to date.
Welcome to the club.
I agree, transitman is an inspiration to us all.
